Any precautions to installing cai?
Old Aug 11, 2006 | 03:57 PM
scv2004's Avatar
Default Any precautions to installing cai?
I just ordered my injen cai and before I install it, I want to know if their any precautions or safety measures I should take to avoid problems. I Know some people have had issues with installs and I want to make sure everything goes in clean! thanks!
Old Aug 11, 2006 | 04:20 PM
BigMURR's Avatar
...There's a tech section look uder the features tab and it has DIYs that should tell you what to do...search next time.
lock it up
Old Aug 11, 2006 | 04:32 PM
__NYTCGunz__'s Avatar
tC squad
The only thing u really have to worry about is getting the o-rings on tight and that u dont mess wit the MAF sensor too much. Such as no harsh wiggling and such its a very sensitive tool. If u mess that up ur not going to be able to go more then like 30 mph. Good luck wit the install!!!
Old Aug 11, 2006 | 07:43 PM
scv2004's Avatar
lock it up
Thanks for nothing, however, I did search and nothing was said. You show me a post that tells me precautions to installing a cai and I would be satisfied. People are just to early to jump the gun and make it a pointless post and tell people to search. It would have been easier if you just answered the question assuming I already search, because I DID!
Old Aug 11, 2006 | 07:44 PM
scv2004's Avatar
Thank you for an actual beneficial post. Where exactly does the MAF rest?
Old Aug 11, 2006 | 09:25 PM
BigMURR's Avatar
here you go, this is how you reset your ecu...one precaution you must know...
(taken from another thread)
NEVER EVER REV THE CAR ON A FIRST STARTUP AND ALWAYS RESET THE ECU AFTER ANY INSTAL OF ANFTERMARKET PART.... i cant stress that enough sometimes to people..
that might not be your problem but for others reading this please please after installing a header or intake etc.. always diconnect your battery for min 5 minutes so the ecu can reset itself. after done installing connect the ecu and start the car and let it idle for 10-15 minutes before reving or driving. the ecu needs to learn WTF is going on now and needs a few minutes to correct itself.
reset you ecu one more time and let your car idle..if anything put everything back to stock and take it to the dealer so they can look at it. and replace anything that might be damaged like the MAF. once thats done just reinstall the CAI and follow what i said. you should be fine once thats done.
hope that helps
Now all you have to do is read the tech DIY and do it word for word and there you go.
Hope that WAS beneficial. And it took me 15 min to find this for you. I may have sounded like an A$$ but all it takes is a little searching of previous threads, and other peoples mess ups so you won't mess up too.
Old Aug 11, 2006 | 09:58 PM
scv2004's Avatar
See, thank you. Now was that so hard? Is it good to reset ecu after exhaust as well? Or only the cai because its actually installed on the engine?
Old Aug 11, 2006 | 11:41 PM
RoswellScion's Avatar
Go spend $20 at autozone or any applicable parts store and get some jack stands. Don't do this without jack stands. That's a BIG precaution.
And, no, you won't have to reset your ecu for the exhaust.
Old Aug 12, 2006 | 12:22 AM
BigMURR's Avatar
No it wasn't hard just wondering why you coulddn't do it...
I'm not too sure I didn't reset it when I did my exhaust and it works fine so you'll have to search for that one. I'm thinking not though because it has no O2 sensor on it, but you can't take my word.
Old Aug 12, 2006 | 04:08 PM
SantaClawz's Avatar
Yes yes, jack stand, very important.
My personal mistake...
https://www.scionlife.com/forums/vie...038&highlight=
Old Aug 12, 2006 | 09:46 PM
njdan69's Avatar
ScionERA
wrap the hole that the intake goes through with some kind of rubber, that will help you avoide some rattles in the future..
Old Aug 13, 2006 | 04:29 AM
scv2004's Avatar
Would installing the BPV with the cai make it easier?
Old Aug 13, 2006 | 03:54 PM
njdan69's Avatar
ScionERA
im not sure about that but I have the K&N ad it hits on the side of the hole that goes in to the wheel well. Oh yeah there is a good chance that it will break the mount that is on the tranny too. If you can find a way to reinforce that you are good to go.
Old Aug 13, 2006 | 05:35 PM
ToyoCel's Avatar
Putting some kind of rubber cushion is a very good idea. Also make sure you secure all part of the intake. i didnt and the sides of the hole where the intake goes through is starting to cut through the piping because of movement when i accelerate. Now im going ot have to get another one cuz im affraid some metal chips might go into my engine if this continues.
Old Aug 13, 2006 | 05:49 PM
ToyoCel's Avatar
LOL Santa Clawz That sucks about dropping your car on the ground. I bet its funny now but i would of been ____ed off at myself if that ever happened to me. The DUMBEST thing ive ever done was change my motor oil (i used royal purple at the time... very expensive at Pep Boys) i put in 4 quarts and then checked if the oil level was right. To my surprise is was empty. i looked under the car and saw that all the oil had drained out!!!! i had forgot to put the bolt back on the oil pan!! i felt like such in idiot. The was the most expensive oil change i had ever done!!
Old Aug 14, 2006 | 01:23 AM
scv2004's Avatar
What would I use to stabilize the cai? Do I have to buy other pieces to securely install it?
Old Aug 16, 2006 | 12:09 AM
ToyoCel's Avatar
Dont worry about having to buy any exztra parts. Just make sure that you do secure it like the instructions say. i didnt follow the instructions because i was in such a hurry to put in on to i didnt bolt everything down. the pipe and filter hit the fender wall everytime i accelerate fast and that same movement is whats causing my pipe to cut. I can fix it its just that ive been to lazy to take off the fender. i better do it though or else ill be having to find time to fix my engine.
hampton1100
May 28, 2015 07:32 AM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
minter66
Dec 15, 2014 01:45 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
