anyone hear a knock when they shift hard??
Old Feb 13, 2007 | 08:17 PM
ef91hatch's Avatar
Default anyone hear a knock when they shift hard??
sometims when i shift hard i can hear and feel somthing hiting somthing. i was thinking its my motor mouts being too soft or something. the car is a tc. its only got 6700 miles on it.
anyone got any ideas?
Old Feb 13, 2007 | 10:44 PM
nodsetse's Avatar
Sounds like the description of a missed shift to me, where the clutch wasn't fully engaged and/or the gears didn't mesh...until you forced them, which was the "something hiting something", as you put it.
Old Feb 13, 2007 | 11:15 PM
trust's Avatar
i hear this too, but only since i've put the ingalls damper on and removed the plastic cover.
Old Feb 14, 2007 | 01:57 AM
ex_dsmer's Avatar
I hear it too but i'm pretty sure its not a problem
Old Feb 14, 2007 | 02:12 AM
tc913's Avatar
Me too.....but this only happens to me when the car is cold.
Old Feb 14, 2007 | 02:14 AM
JOEinSD's Avatar
if it's a clunk then it's normal. lots of people hear that too.
Old Feb 14, 2007 | 02:21 AM
IcetC's Avatar
yea i get it once in a while when i'm stopping on it from 1st to 2nd but i don't think much of it at first i thought i was a grind but i dont think it is
Old Feb 14, 2007 | 03:16 PM
ef91hatch's Avatar
no i know what a mis shift is.
Old Feb 15, 2007 | 05:25 AM
newt0n's Avatar
its a car with many metal parts moving around at high speeds clanking will occur. that is my .02
Old Feb 20, 2007 | 12:03 AM
ef91hatch's Avatar
what a wortless post. ive driven many cars with many metal parts. none have made this sound before... just my .02
Old Feb 20, 2007 | 12:14 AM
Jan06xB's Avatar
when does it happen . . . when you shift or let the clutch out or when you hit the gas after the clutch is out?
Old Feb 20, 2007 | 12:22 AM
redwar1441's Avatar
is it like when slamming second and you get a little wheelspin and you hear a clunk! if thats what it sounds liek its the motor mounts hyperextending. Get an ingles engine dmpaner and it should go away. Mine does it everytime i slam second, in every tc iv ever driven(which is alot)
Old Feb 20, 2007 | 12:34 AM
Jan06xB's Avatar
Could be the motor mounts bottoming out or you are hitting 2nd gear at too low an rpm and when the power comes on it bangs from the play in the drivetrain.
Old Feb 20, 2007 | 01:03 AM
ef91hatch's Avatar
it makes the same sound when i wheel hop from no raction
Old Feb 20, 2007 | 02:40 AM
Jan06xB's Avatar
Ok the engine mounts move a certain amount then they bottom out and it would happen more in lower gears because the gear reduction in the tranny generates more reaction torque on the engine when the wheels grab - that's why turbos in 1st and 2nd break things. You could also be working loose rivits in the clutch disk but more likely the motor mounts - look under the hood for metal to metal contact on the mounts or it may be the lower mount on the bottom - one xB actually loosened the bolts and the threads were rubbing and it slid in the hole. Or take it a little easier - you will break something eventually if you keep beating on it!
Old Feb 20, 2007 | 07:27 PM
redwar1441's Avatar
like i said, its your motor mounts, get an ingles stiffy and you'll be fine. Ive only seen one broken motor mount on a scion and it was supercharged and i seriously ____ed up, i missed 4th....went into second yeah i know im a moron it was mid corner and i was getting thrown all around inside the car racing it and i slammed 4th or so i thought and broke the front motor mount.
Old Feb 26, 2007 | 09:29 PM
ef91hatch's Avatar
im not beating on it. sometimes you have to down shift in traffic to avoid things or speed up. i baby this car and if that is gonna break it then i should get rid of the thing right now
Old Feb 26, 2007 | 09:33 PM
redwar1441's Avatar
not to start a fight but hes an xb driver with a little dinky echo motor. The tc is very durable. Take it to your local dealer have them check it out, its probably the motor mounts clunking during wheelspin. You did mention you dont beat on it tho. Bring it to the dealer see what they say.
Old Feb 27, 2007 | 03:29 AM
Jan06xB's Avatar
Hey I've driven a 65 rambler American with a flat head 6 for 9 years 100,000 miles a 80 VW rabbit with the small engine for 12 years 163,000 miles and a 1994 Geo Metro for 12 years 90,600 miles and NEVER have to down shift to get out of the way of anything. My xB has more HP than anything I have driven and more than I need. You better learn how to drive!
Old Feb 27, 2007 | 05:39 AM
xjamiex's Avatar
Hey i hear it too and i made a dent in my MMW Spipe and the MMW guys told me i have a blown motor mount which i know isn't true because my previous tc did the same therefore they won't warranty my headers. I bought and engine damper from MMW and to me it wasn't that great. it works but its poor. no matter how much tighten the nut i always have to check it because it comes lose. and i get scared it might fall on to something i don't want it to. (belts) I still get the clunk though sometimes i feel like i heard 2 things hitting i dunno. should have paid more for ingals. Also let me add this the clunk makes the car lag for 1 second anyone notice that?
