To anyone with a oil Pressure gauge.
Old Jan 10, 2006 | 10:58 PM
yamaha16bw's Avatar
Default To anyone with a oil Pressure gauge.
Hey I have a quik question about oil press. gauge's on tC's. I just installed the Cobalt 0-100 psi oil press gauge and I was just wonder what psi the engine runs stock? When I started the engine it was about 40 psi after I let it warm up good it dropped to 20 psi. So at idle Im at 20psi and under high RPM to goes up to about 70psi. Does this sound right? First timer here.
Thanks
Old Jan 10, 2006 | 11:16 PM
Munch's Avatar
Yeah that sounds right.
Old Jan 10, 2006 | 11:17 PM
yamaha16bw's Avatar
Thanks
Old Jan 11, 2006 | 08:16 AM
mwuf15's Avatar
did u use a oil filter adapter to install the oil pressure line?
Old Jan 11, 2006 | 10:53 AM
Munch's Avatar
I used a Greddy oil block adapter.
Old Jan 11, 2006 | 11:28 PM
yamaha16bw's Avatar
I used the GReddy block adaptor as well. I used autometer gauges and had to have the hole for the sensor re-tapped because the threads on the sensor were too big.
Old Jan 12, 2006 | 03:18 AM
mwuf15's Avatar
so did u guys who use a greddy block adapter, use a different size oil filter? or did u use the same size oil filter?
Old Jan 12, 2006 | 03:21 AM
Munch's Avatar
Factory oil filter.
Old Jan 12, 2006 | 03:56 AM
yamaha16bw's Avatar
yeah me too. Just used stock filter
Old Jan 12, 2006 | 08:30 AM
mwuf15's Avatar
i heard that some people who use a oil filter adapter, they have to use a different size oil filter. anyway, where u guys get this greddy adapter from? i want one for my oil pressure gauges.
Old Jan 12, 2006 | 08:17 PM
yamaha16bw's Avatar
http://www.rallysportdirect.com/shop...roducts_id/736
I didnt get mine from there but thats the same adaptor.
Old Jan 13, 2006 | 12:06 AM
mwuf15's Avatar
the site saids that it fits the 02-04 wrx and the evo. so does it fit the scion tc?
Old Jan 13, 2006 | 01:21 AM
yamaha16bw's Avatar
yes it will fit
Old Jan 13, 2006 | 01:29 AM
yamaha16bw's Avatar
I went back and looked through my old emails. This is where I bought mine http://store.racerwheel.org/tp-12002801.html Like I said though, If you plan on using autometer gauges you will have to have the sensor holes on the adaptor re-tapped. The AC adaptor will fit autometer gauges you just wont be able to use the stock filter.
Old Jan 13, 2006 | 01:47 AM
mwuf15's Avatar
what do u mean re-tapped?
Old Jan 13, 2006 | 03:39 AM
yamaha16bw's Avatar
The sensor itself will screw into the adaptor. The threads on autometer sensors are too large to fit into the threads on the greddy adaptor. I took the adaptor to a machine shop and the re-tapped(meaning make the hole for the sensor larger) for free. It's really not a big deal.
Old Jan 13, 2006 | 04:35 AM
mwuf15's Avatar
where did u go to make the hole larger? for free?
Old Jan 13, 2006 | 03:25 PM
yamaha16bw's Avatar
I just took it to a machine shop. Anyway that does metal work should be able to do it. I dont know if I got lucky but they didnt charge me a thing. They said it only took about 15 mins to do it and not to worry about it
Old Jan 14, 2006 | 12:51 AM
mwuf15's Avatar
u lucky.
Old Jan 14, 2006 | 02:16 AM
Sam_J84's Avatar
i see now that greddy offers 3 different thread sizes and 2 diff. o-ring sizes. do you still have to modify the adaptor?
