auto valve body upgrade
Old Jun 17, 2009 | 04:53 AM
slayton00's Avatar
Default auto valve body upgrade
if i got one on my auto would you see a difference with all n/a bolt ons?
Old Jun 17, 2009 | 12:41 PM
BlackKnight's Avatar
Music City Scions
Default Re: auto valve body upgrade
I don't have either but it would help the life and strength of your transmission after doing this and adding a trans oil cooler.
Old Jun 17, 2009 | 12:57 PM
tcchris38's Avatar
I guess you could but I dont see just bolt ons taking your trans to the slippage point. But im sure it could still make you shifts better and faster
Old Jun 17, 2009 | 01:25 PM
stillettoDSM's Avatar
Firmer Shifts, but don't get a Trans Cooler right away, it can actually damage your Transmission, because it can drop the temp lower than the normal operating temp, unless you drive fast and hard, then go for it.
I wouldn't do the Valve Body, because you're not gonna' need it.. PLUS, why Void your Warranty? If your Trans fails, then just take it in, and its covered.
Old Jun 17, 2009 | 01:58 PM
Music City Scions
A transmission cooler will not damage your transmission it is better for it to run cooler. It will not cause the temp to run at such a low temp like you are thinking. OEM transmission isn't built well on the tC's and the life of the transmission will be extended.
Old Jun 17, 2009 | 02:05 PM
XD40tC's Avatar
Yeah I dont see a cooler being a problem. The thing still got hot when I had one on mine. I needed a bigger better coooler!
Old Jun 17, 2009 | 02:36 PM
Yeah, what I want to do is get a Trans Temp Gauge and monitor the Temperature Stock, then get a Cooler and see how it performs. Probably next month or so.
Old Jun 17, 2009 | 02:39 PM
Also, B&M makes a Cooler that has a Fan attached to it that turns on at 160 Degrees.
tckid21
Mar 12, 2017 09:16 PM
anti_virus347
May 28, 2015 06:01 AM
anti_virus347
Apr 3, 2015 05:17 PM
cid_mcdp
Jan 5, 2015 02:45 PM
wesley_t
Dec 18, 2014 06:59 AM
