BIG RASP PROBLEM! HELP!
alright guys i got a bigg problem and im pretty ____ed now....first off...heres wut i've got....greddy evo2 exhaust...injen cold air and now alphawerks headers......before with my injen intake and greddy exhaust my car sounded realll good.....i put on the alphawerks headers 2 days ago and its allllll raspy....how could headers do such a thing???
Are you joking?...there are literally hundreds of posts on here about header rasp. By removing the precat built into the header you are dramatically increasing exhaust flow. If you want to cut it down you will need to add a resonator but it may not eliminate it completely. Mine is a little raspy and I have the stock exhaust..yours must be ridiculous.
I had the same awhile ago. The greddy evo2 system wasnt design to handle the air flow from an aftermarket header. I got a bigger resonater, but that didnt help much. so i bought a HKS exhaust and it fix the problem. Try searching my posts.
Guest
Posts: n/a
I have the solution to the header rasp problem right here, Precisionmuffler.com has a special on our axle backs for the tC. Our axle back keeps your exhaust system at a low note and deep tone with your header on!! We have the axle back to solve the rasp problem right here!! We installed our axle back on a tC with the MMW race header and found that the sound was deep and helped get that raspy sound away. Check them out here at www.Precisionmuffler.com
It causes some rasp as well..people with the Megan racing header claim little to no rasp and the MMW header is also not known to rasp although it is way more expensive than anything else.
damn this sucks so bad.....i guess im looking at changing either my exhaust or header....sounds like theres no real way to get around this, and from what im hearing a larger resonator doesnt do much.
I have the megan header, which will be equivilent rasp wise with any of the others and run the precision axleback with no rasp.... and love it....
Best Header friendly muffler setup out there.... you can even listen to it in my sound thread!
