Blue smoke...help
My tc has been giving me extreme trouble since my last oil change, which was about a month ago and it was done at firestone. For starters the car feels like its running on 3 cylinders, its burning a ridiculous amount of oil, my gas mileage is horrible. When i pull off, the exhaust just pours out blue smoke, and also when i have the clutch engaged theres a rattling sound and the idle drops to almost a stall..
My car was running a little sluggish before, but nothing like the way it is now since i got that oil change..could it have been something firestone did wrong? Im about 200 miles away from 100k and ive started maintenence, spark plugs, new filters, tranmission fluid change etc..but i have 2 CEL's that read p0012 and p0011..I've done my research on here but i need a direct solution, any ideas guys??:pray: |
Don't expect a direct diagnosis from behind a computer screen unless someone has had this happen to them before. If you Google those codes, they have to do with timing. One is for timing being over-advanced and the other over-retarded.
http://www.obd-codes.com/p0011 http://www.obd-codes.com/p0012 The symptoms are right on par with what you're describing. |
Originally Posted by Jon
(Post 4046777)
http://www.obd-codes.com/p0011 http://www.obd-codes.com/p0012 The symptoms are right on par with what you're describing. That was the purpose of this post to see if it has happened to someone before. I'd rather go to the dealership or wherever knowing exactly what's wrong with it so i can tell them exactly what needs to be fixed, and not have them charge me an arm and a leg for unecessary things. |
Without having the car in front of us, there's no exact way to know considering those codes have more than one cause listed. It could truly be timing, or it could be a wiring or sensor issue. There are tools for checking timing, but of course one would need the car to do so.
Id start with clearing the codes and then seeing if you get the same ones again. Find it strange that your getting too much timing and too little timing together.
Originally Posted by STlTCHES
(Post 4046811)
dont quote me on this but with the blue smoke at idle and the 2 codes I bet your getting "Continuous oil flow to VCT piston chamber" which came oem 07+ |
burning oil probably coming from piston rings
(Post 4046815)
(Post 4046811)
See if you can get a junkyard/used motor and sell yours for parts
Originally Posted by dhooks90
(Post 4046757)
]firestone
Problem number one. Chances are they didn't do anything to it. Then again, how will you ever know. :nails: I've worked on top of 200F degree asphalt in the dead of summer in the middle of parking lots just to avoid grease monkey shops like that. The piece of mind you get is priceless. Never know what some inbred with no high-school diploma is doing to your car behind that counter. |
Originally Posted by PRODIGY3000
(Post 4047573)
Problem number one.
