Boost on TRD Supercharger?
So, mcgeorge has the TRD supercharger listed on his site as pushing 5psi. Now, I've just been looking at turbos, and I understand that the more boost (psi) you put, the more power you'll put out. 6psi, 8psi, 12psi, whatever. What I want to know is if a supercharger is the same way? Can you adjust the psi on a supercharger to make it crank out more power?
Yes, but on a supercharger you need to decrease the size of the pulley on it to make more power. However, the tC's motor is a high-compression motor so you'll want to be careful when boosting more. Otherwise all that will be blown is your rings or head gasket
The reason I'm asking is cause I think the scionspeed turbo is pushing 15psi now! I think 8psi or 10psi without major engine mods. So I wanted to know how it would be with the TRD SC. I dont' know much about SC.
But if I'm not mistaken, witha turbo, you can get a boost controller to make boost adjustments simple. For example, running 6psi daily, then turn it up to 12psi for track days? Is anything like this possible with a SC?
Originally Posted by jaycarneygiants
McGeorge does not list the PSI for the TRD tC supercharger. Where did you locate that info?
Originally Posted by Jdawg82
As a general guidline every 1 psi of boost equates to aproximately 10 hp gain. So if the supercharger is running 5 psi that is a 50 hp gain at the crank, making about 210hp overall.
I'm pertty sure the tC can handle in everyday basis 6-8 psi easily, consider the TRD supercharger kit will come with ECU upgrade and (4) fuel injectors upgrade. A 9.6:1 compression, along with the known Toyota reliabilty, is good for med-low high boost, i.e from 6-12 psi in either force induction: Turbo or superchager. If the F.I. setup includes an intercooler setup then the levels can be higher like 12-15 psi
I just want to say this about boosting thier isn't that much diffrent in running
9.6-1 cr and boosting 5psi
then running
8.6-1 cr and boosting 10psi.
All I am saying higher compression = less boost and lower compression = higher boost. Unless your planing on boosting 14 or more psi the factory cr is fine.
think about it all you are doing is decreasing the cr to boost more just to get the same if you keep the cr and boost less. I hope every sees what I am saying.
then running
Not quite. Not every motor isd the same. 5 psi in the tc with a compression ratio of 9.6:1 will make more power than say GM's 3800 Supercharged Series II which has an 8.2:1 compression ratio. When I had my Buick (with the aforementioned motor) I was running about 14psi... and I know I wan;t making an extra 140 HP from it.
