brake question
hmm.. brake pads..
i'd say Axxis Ultimates.
but you can also ask our resident brake expert here. ( The_Instigator )
it depends on what you're looking for... if you're going to need it for track purposes and whatnot..
sIcKsCiOnS
DelMarVa
Scion Tuners
Originally Posted by manwezy951
im about to hit the 25,000 mile mark and my breaks seem fine still. but when they will start to go, what brake pads should i use or should i just go warranty>?
no warranty buddy, sorry. wishful thinking
unless your rotors are at fault, brakes are wear/tear item
if you've got 25k on them, and still feel fine. dont change them yet unless you really want to. they should be inspected when you get your oil change,etc.
sIcKsCiOnS
DelMarVa
Scion Tuners
i dont race.....track....just daily driver pads..... but how much do those axis pads run for?
www.vividracing.com
Originally Posted by SquallLHeart
umm.. i think the axxis deluxe plus runs at about $38 a pad for the front.
Erik... you can chime in anytime you want and help out..
The Axxis Ultimate have more bite than just about any other street pad out there which provides a better pedal feel and more performance than stock. They also produce more dust than stock which may turn you away form them. The Deluxe Plus have bite levels more similar to stock along with very low dust levels. They are different pads for people looking for different things, but neither will dissapoint when it comes to performance per dollar.
^^there he is
yeah.. my only comment about the Ultimates is pretty much the same.. much more bite, but much more dusty.
that's why 2nd time around i sugessted the Deluxe Plus more. figured it'd be a little more above stock level (bite-wise) and low dust. something that i think you wouldn't be disappointed in.. (and they're cheaper than the Ultimates..
I have actually switched to the Hawk Performance Ceramic pads since I wanted less dust than the Ulitmates. They have dust levels similar to the Axxis D+ or Hawk HPS but with only a minor reduction in bite form the Ultimates...but alas Hawk does not supply these pads for the stock tC calipers at his point. Hawk also does not offer any rear tC pad yet, but hopefully the Performance Ceramic will be available soon for the front and rear.
The Hawk pads generally cost more than the Axxis pads (usually 50% or so) but in my opinion the Performance Ceramic compound is one of the best street pads out there right now.
Sorry to temp you guys like that, but if its any consolation, these pads can be used now if you use our big brake kit
hey guys, i just changed my brakes to ceramic pads and my right side is screeching pretty bad when i step on the brake a bit. but the left side doesnt make a noise. i also noticed the right side makes a smell like charcoal burning, im not sure if these things are normal. could you guys tell me whats up. i took the pads off and put them on again but nothing changed.
bootlgr
Jan 26, 2016 01:22 AM
