Cams for Scions!
Cams for Scions!
Hey guys. How are you all today!
Well for those of you that dont know my name is Ryan and I work for Stripper Motorsports, in Michigan.
I like you am a Scion owner myself, owning a BSP 06 tC and SR 06 xA.
My tC is on its way to being parts and pieces because I plan to do an engine rebuild, along with Stripper Motorsports doing a rebuild on a freinds xA. While we have these engines apart we are have custom Cams made for them.
I am hear to see who would be interested in a cam for your tC, xA, or xB.
We are looking to just gather interest as of now and then probably in a month or so get something started if we have enough interest.
Currently we have the worlds fastest Trailblazer SS, the 5th fastest Syclone which is now being rebuilt and will be the fastest, and working on the Scion tC and xA to make the fastest, and lastly a 95 Eagle Talon which we plan to make the fastest!
We like to go fast !!
SO anywho, please post up wat you think about these cams and if you would be interested.
thanks
Ryan
thanks
Ryan
The intrest is there, but from prior experinces the gains arent really worth the costs from what ive been told. Sorry this isnt VTEC where you can get hella gains just from changing out your cams.
theres us HUGE interest in cam for this car. however most of the work will need to be done controlling the timing which is what give us our downfall. BUT if you develope a good power producing CAM. i would defenitely purchase it lol..
VVTI timing advancement has a huge range, something like 60 degrees. If there's no way to keep this in check with a larger lift and duration, the results can be catastrophic.
However, I don't know how the ECU monitors the effects of timing adjustment other than knock/AFR sensors... In addition, even small changes to the cam profile should make halfway decent power when combined with the ECU's monitoring.
I'd be sure you guys test the crap out of it before release
Would be nice, but the whole VVT-i setup is just not something I would want to mess with. VTEC on the other hand, now that's easier. Just sucks that we gain on the intake side while VTECs gain on both intake and exhaust.
The cams are all going to be special order / custom grinds. Specs of the cam will be determined for the engine application that they are going to fit. Basically you tell us what you have done to the car and engine and we will spec a cam to accordingly fit your application. Once we get some real world testing in our cars we will start to offer shelf cams that can be used in common set ups for the cars that they fit.
Also until we take it out and see what we can do we wot have an idea, obviously hoping to low cost high gain but will keep you informed as it progress. Just wanted to see the interest in it!
Hope that clear things up a little for you.
cam pricing usually stays under 500 unless you wana be a baller and get some toda or stage 2+ type cams which by then you will need up upgrade your valve train and tear into the head.
the key thing to keep in mind is going to be controlling the vvti. once you have mastered controlling the degree of the lobes then i would suggest goin deeping in creating a bigger lift.
i guess it will come down to how much the cams will cost and how much will be needed there after to support the new cams. IE: timing control and fuel control.
i would rather see development into a new intake manifold then cams. but if you guys can do custom grinds and make some ponies then more power to you!.
RippMods is testing a cam specifically for the TRD f-trim SC in my car right now. Nets some pretty impressive gains. They're working on a stage 2 right now that will also make up for the torque loss incorporated with headers.
Originally Posted by deathbyc4
you might as well sell staged heads if you're going to go the route of changing the cams with valvetrain. I'd like to see some more head options.
