Car barely starts up
In the morning (and usually only in the morning) when I start my car, it sounds like it doesn't want to start. It seems like it gets pretty close to stalling, but then it starts. It sounds fine afterwards. I do have an Injen CAI and a Tanabe exhaust and 111K miles. However, I think it was doing this back when I first got the car and before the mods were installed, but wasn't this bad. It's gotten worse over the last couple of months.
Any suggestions or more info needed?
In the beginning, that's what it was like. But now, it's leaning more towards the not starting part than ever before, so if there's a problem I'd like to get it figured out before I get stuck somewhere.
Originally Posted by SW_08
i think i know what you're talking about...sometimes it seems like the car doesnt wanna start but it does....you're not going crazy...lol
sometimes i notice but honestly idk.....*shrugs*
Originally Posted by RammsteinNicCage
Probably not, but it really wasn't giving me a problem right after changing the battery.
I pretty sure its your battery. I had the same problem and it got to where I had to turn the key a few times in the morning for it to start. there were times the crank wouldnt even turn at first. You probably got a bad battery off the shelf...its possible. take it back and ask them to get your money back and get a new battery. there should have been some kind of 60-90 days return or something like that for it. if anything have then test it. A friend had the same problem with his 97 blazer and i told him its probably his battery. he went and got a started and then when we jumped started his car, it worked. Couple hours later he got a battery and hasnt had a problem since.
Why do people insist on putting premium in these cars? *sigh* your just wasting money...
Anyway OP..if the battery is fine the next thing to check would definitely be your starter..with that many miles on the car it's getting about that time where it's gonna go bad
Anyways, I think it's fuel related issue with my car since it only has 15,000 miles. I tested my battery with a volt meter, and it read within spec (12.6 volts). It's hard to just take it to the dealer since it's not a replicable problem. And if the mechanic can't replicate it he won't even bother. I'm gonna run that 44K fuel system cleaner, and I'm gonna switch to a slightly thinner 30 weight oil. I'm also gonna get rid of that TRD oil filter I've been running. I'm gonna put on a Denso/OEM filter.
OP: To check the starter you're gonna need an Ammeter and an Ohmmeter. Check out sections 19-1 and 19-2 of repair manual on SL's tech section here. https://www.scionlife.com/tech/
cid_mcdp
Jan 5, 2015 02:45 PM
jaspercanda
Dec 28, 2014 10:09 AM
