Car dies after supercharger removal
Wow, i remember installing my turbo kit, my one injector wouldnt seat right and when i went to crank it would start and spill fuel all over..... Crazy it didnt do that with you...
Glad you figured it all out
Originally Posted by tCtCtC
the spark plugs COULD be a problem, considering their 1 step colder
Things to check if you think you have a vacuum leak assuming if you keep your foot on the throttle and it stays running, get some carb cleaner. Have someone maintain a steady RPM and spray the carb cleaner around possible places it could be leaking if the rpm changes then you know you do have a leak. I don't know how the maf setup is on the supercharger but it could be the maf sensor bad. Try to use some maf sensor cleaner, clean the maf, disconnect the battery for 10minutes,reconnect the battery, then start the car leave everything off and see what happens.
TheTripleC
01-04-2015 06:46 PM
