Car Pulsing
So I have noticed a new problem that has been going on with my car. Not really a problem just kind of annoying.
When my car sits in idle at stops or just warming up the engine will begin to pulse. The rpm stays the same just seems like the engine is kicking ever so slightly.
Wondering if any once else has experienced this or has an explanation for why this occurs.
well with mine pretty much anytime you start it it will say idle a lil less than 1000 and bounce up and down around that. even if the motor is hot or cold. idt its a problem or anything but idk. and the a/c is turned off so it shouldnt be the compressor
Check for vacuum leaks and fouled plugs then. The only other things it could be are expensive and unlikely (O2 sensor, MAF Sensor, Throttle Body). A small and smooth amount of idle hunting is normal while it is warming up but if it's already been running at operating temp for a bit and it still does it constantly then you should start poking around under there.
No CEL. Happens when the car is warm or cold. RPMs stay the same always happens when it is under 1000. I did start to notice this when I took off my CAI and reinstalled the stock air box. Maybe this could be it. Can't remember if I disconnected the battery when I did this. Maybe just need to restart the ECU.
Ill check the plugs tomorrow.
What should I be looking for with the plugs? How or where should I check for vacuum leaks?
Reset the battery if you changed intakes. Check for small vacuum leaks. Beyond that, it may just be normal depending on altitude/temp/density of air... it's common to have that on turbo setups but not OEM lol.
TheTripleC
Jan 4, 2015 06:46 PM
minter66
Dec 15, 2014 01:45 PM
