check engine code
Old Aug 23, 2005 | 03:01 PM
seminoles68's Avatar
Default check engine code
does any one know what this means
P0038 ho2s bank 1 sen 2 circuit heater
Old Aug 23, 2005 | 03:13 PM
aarontrini85's Avatar
call these ppl they might know
http://www.actron.com/publish/2005/0...lish_16298.pdf
also you left out the word high at the end of that
Old Aug 23, 2005 | 04:46 PM
WeDriveScions's Avatar
Any chance you have an aftermarket header on that baby?
If so.... TADA. Go antifouler or O2 Sim.
Old Aug 23, 2005 | 05:44 PM
reagulator's Avatar
I have a header and my code is p0420 Catalyst System Efficiency below Threshold
Old Aug 23, 2005 | 06:14 PM
BiG_ReD's Avatar
nope dont know
Old Aug 23, 2005 | 11:01 PM
zoltiz's Avatar
N.G.S.O.
Seminoles, you need to hang out with real *real* car guys ;)
Here are the trouble areas for your DTC (P003:
- Short in HO2 sensor heater circuit
- HO2 sensor heater
- EFI relay
- ECM
My guess would be is that sensor heater or heater wiring was damaged when you took the sensor out, it's the one on s-pipe, btw. The fix - new sensor, luckily that second one is cheaper than the one on the header.
P0420 possible trouble areas:
- Gas leakage from exhaust system
- A/F sensor (sensor 1)
- Heated Oxygen (HO2) sensor (sensor 2)
- Front exhaust pipe (Three–Way Catalytic Converter [TWC])
My guess is that you have an aftermarket header that eliminated first cat, so your fix would be to get this famous cheap anti-fouler mod. If that does not help - then a real 02 simulator, if not - put stock cat back ;)
daniinpitt
Apr 4, 2015 08:07 PM
tersmurf
Jan 16, 2015 11:34 AM
greytc
Jan 12, 2015 09:49 PM
AdmirN
Jan 5, 2015 10:19 PM
rcflyer15
Dec 5, 2014 05:15 PM
