Clutch will not engage (CHECK THIS OUT WTF!!!)
Driving into work today I realized that my clutch does not want to go back into gear. I pumped the clutch a few times and got it into gear to get to work and now I'm hosed. It will not go into gear when the car is on, it wants to try and creep forward if I try and put it in gear.
I do not see any fluids leaking near the Master Cylinder or the Slave cylinder.
Could this just be air in the lines? The clutch and the flywheel and release bearing are only about a year old.
Please help, thank you.
Dang I thought you started this thread at ~10am and posted a pic of the clutch 20 minutes later I was about to say that was the quickest clutch removal I ever saw in my life.
Solution.....either get a better clutch or contact 'spec' for a replacement but who knows, it may happen again with another 'spec' clutch.
clutch/gear shift problem 05 tc
I am having this same issue one minute shifts fine the next I either cant get it in gear and grinds when i try or have to shove it in gear. also have had it creep forward if I try and put it in gear.
any thoughts
any thoughts
mischman
03-31-2015 03:16 AM
Inazuma
14
01-08-2004 01:36 AM
