Crank Pulley or Sway Bar?
Old Oct 19, 2005 | 03:40 AM
bdballer69's Avatar
Default Crank Pulley or Sway Bar?
Agency Power better or Nonstoptuning is better?
Can ppl who got either one tell me what's the advantage of what you have?
I am planning to get myself a bday gift i can decide to get the TRD Sway bar or the Crank pulley...
any postive feedbacks are welcome. Thanks in advance
Old Oct 19, 2005 | 03:48 AM
The_Instigator's Avatar
Id get the sway bar. I put mine on a few weeks ago and it makes the car way more stable. I dont feel like the pulley is a safe mod to do on a daily driver you need to rely on for the next few years. Theres potential for serious engine damage with it, that Im not willing to risk for a few HP.
Old Oct 19, 2005 | 03:59 AM
-NEMESIS-'s Avatar
I got the pulley advertised 10 hp 11ftlb .... and it actually feels like there is less engine vibration. much more power. revs are much quicker, mileage is better. But i would recommend the sway first. decide how long you are going to keep the car. I have heard both it is good and bad. Agency power says thier motors actually look better internally with the light pulley than stock, but the pulley removes the engine harmonic balancer. (little rubber ring on the stock pulley) which would cut engine life if the new pulley and motor wasn't perfectly balanced. As for me the tC is going to be gone as soon as the new "supra"comes out maybe a skyline? as long as they don't ruin it.
Old Oct 19, 2005 | 05:06 AM
bdballer69's Avatar
thanks for the quick reply...i was thinkin about the sway bar too...is it hard to install yourself?
Old Oct 19, 2005 | 05:23 AM
Not at all. You can do it on ramps with the tires on even. Hardest part is getting the bars in and out..its a tight fit around the exhaust pipes.
Old Oct 19, 2005 | 05:47 AM
Sam_J84's Avatar
if u get the pulley....get the NST one... i got it, and its awesome.
Old Oct 19, 2005 | 06:22 AM
87na's Avatar
Id have to say both are good mods, neither a pulley or sway bar are SUPER hard to install, they just take certain tools. The best part is that even if you dont have the necessary tools, a good shop shouldnt charge more than 50 bucks or so for the installation.
That having been said, I have some NST pulleys and I have had good results. Check out this link for some good info...
https://www.scionlife.com/forums/viewtopic.php?t=88702
Old Oct 19, 2005 | 02:52 PM
-NEMESIS-'s Avatar
does the nst pulley have that ring in it? Or just 1 piece of aluminum?
Old Oct 19, 2005 | 03:32 PM
Solid aluminum...no damper
Old Oct 20, 2005 | 06:11 AM
87na's Avatar
none of the aftermarket pulleys available for the tC have the rubber dampner. from the most expensive (unorthodox) to the most affordable (NonStopTuning) they are all solid aluminum. I have not had any problems due to the lack of the rubber dampner in the past few years, good luck man
Old Oct 20, 2005 | 07:46 AM
Dr_Isotope's Avatar
Suspension first, always. The pulley will work when you're accelerating-- which is about 30% of the time the car is moving. The sways affect handling... well, pretty much all the time. You only have as much power as you can put to the ground.
Old Oct 20, 2005 | 09:55 AM
WingspanTT's Avatar
how much should a sway bar cost?
Old Oct 20, 2005 | 10:41 AM
superbill's Avatar
i cant wait for lo bux to see this...and a sway bar should not cost anything!..should be for free! but actually it depends on what sway, some are better quality than others
lets see there are only three or four companys out that make sways for our car and the lowest ive seen is T R D around 130.00 .
NonStopTuning
Scion FR-S Drivetrain & Power
14
May 5, 2017 06:52 PM
maximthegreat
Jan 19, 2016 02:31 PM
Bmfxtreme
Aug 18, 2015 01:25 AM
xjleitex15
Aug 18, 2015 01:23 AM
Subaru86
Jul 31, 2015 04:00 AM
