drinking oil...
seriosly my car has been consuming oil like it was beer....i need help...my car has also been smelling everytime i step on da gas...any suggestions on where to look or how to solve this problem?
mine loses oil every 5k miles(every oil change) depending on the driving conditions if I beat on it or not. it vary's from a quart to a quart and a half/two, always mid way at 2500 miles or so.
but my car has 113k miles so I figured its old age too, but it has happened ever since I've owned my car, I remember reading it was due to the lack of oil squirters that the 05-06 lack.
I also have i/h/e but I don't smell the exhaust fumes that u speak of unless I seriously beat the ____ out of my car which isn't often.
jon, the manual says a quart is normal?? I don't even have the manual anymore, if its normal I have nothing to worry about lol
Yeah it says 1.1qt per 600 miles is normal. But if you're consuming that much you should keep an eye on it to make sure it stays full until the next oil change.
well, first things first. when you start your car on a cold start are you getting an excessive amount of smoke? (only on cold starts) also, if you disonnect your pcv hose from the intake is there any oil mist coming out while the car is idling?
The oil is either going through the combustion cycle or is leaking out somewhere. Like a earlier poster said it's got to be going somewhere.
I would take a very detailed look around the engine bay and under the engine for signs of leaking. Burnt oil eesidue sludge etc. If you don't find anything, you might want to test the compression.
