Engine Coolent leaking problem..
Old May 1, 2020 | 03:53 AM
Bray0607's Avatar
Default Engine Coolent leaking problem..
I have a 2006 Scion tC and it's leaking coolant. I checked all hose leading to radiator and all are good.
I found it leaking from behind the engine under some black cover that seems to be covering the headers.
Could anyone tell me what could be wrong? Much appreciated.
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; May 1, 2020 at 05:29 AM. Reason: Moved to Correct Forum by Administrator
Old May 1, 2020 | 02:13 PM
J_Leon's Avatar
You might want to check your water pump,
in some cases they start to leak when they are failing,
also check your thermostat housing.
Hope that helps!
__________________
xr1ckx
Feb 5, 2018 08:55 AM
Yosoyfresko
Jan 10, 2014 06:32 PM
Mauby
May 15, 2012 08:14 AM
zx8DragoN8xz
Nov 15, 2007 08:07 PM
metsvenand
Sep 30, 2007 03:22 AM
