Engine went POOF
So I got a call from my body guy amd my car engine blew. It has a hole where the pistons and shiz is located, so now I am towing the car to Ptuning where it will hopefully be getting fixed...
If anyone has or know someone/where that has a motor for sale for cheap PLEASE let me know.... also if they have a manual trans with it since I do want to do a trans swap possibly.... Thanks for any help.
I am sooooo sad andf ____ed right now since money is already tight and now this....
Originally Posted by jaxtcracer
what happened? if you dropped it off at a body shop with no engine trouble, how can it all of a sudden be POOF????
There was a small issue when I dropped it off with white smoke when I let off the throttle but I didnt think this would happen and the body shop was with a friend that worked there I know he wouldnt do anything to F with my car...
\Well came back from Ptuning and wat happened was the vacuum line came off so no oil was going where it needed to and boom hole in my block.... oil starvation...
I'm not going to doubt that oil starvation could've caused the problem, but there would have been warning signs, such as rod knock before it went that horribly. If there were a bad tune and the car was ran really hard then it could've cracked a piston and tore everything up. Definitely sucks though, I feel for you.
Originally Posted by fox
Vacuum line to the BOV came off that ties into the pressure sensor. Lots of boost and no fuel.
***EDIT***
...and what pressure sensor? tC's are MAF-based cars, they don't have MAP sensors. The only way you'll have a MAP sensor is if you have either an electronic boost gauge or you have an AEM unit.
I want to see a 3vz-fe from 95-97, 208hp 200tq in a tc. You need a new motor anyway, do the swap. You should be able to get one from australia. Don't know if the trans from a tc would works. But it would be a awesome swap. The motors from a camry thats we don't get in the states. Don't get the us spec its only got 180 hp 188tq.
