exhaust rattle shake help?
Old Jan 13, 2008 | 03:11 AM
svencarlson07's Avatar
Default exhaust rattle shake help?
hey iv had my cai and catback exhaust for a while and it was fine but the other day i isntalled header and s pipe and the shaking is redic and its hittin somethin..does any1 kno of anythin like a vibrate damper or somethin thats able 2 go around the exhaust thats hittin my frame? any help wud be great thanks
Old Jan 13, 2008 | 03:31 AM
mengsta's Avatar
You would probably need to explain more, on how the sound is. how often it occurs. But in my share of experience i have had rattles on the heatshield above the midpipe. Also a rattle could be the s-pipe hitting the frame. If the rattle occurs when idling, then that is an easy fix. Just start the and lift it.
Old Jan 13, 2008 | 03:35 AM
yeah its the s pipe hitting against the frame but also the end where the exhaust tip is shakes ridic now also... wut u mean start and lift?
Old Jan 13, 2008 | 03:40 AM
mengsta's Avatar
well you can start the car lifted up, get under and target the rattle. That is if you didnt know where the rattle was from.
Old Jan 13, 2008 | 03:42 AM
yeah i know where its from..any ideas how to stop it?
Old Jan 13, 2008 | 04:12 AM
DonNguyen's Avatar
well..whats it rattling against?
Old Jan 13, 2008 | 02:11 PM
i think its teh s pipe hitting against the frame..u kno where its rly close in the first place
Old Jan 13, 2008 | 02:25 PM
bkuhl's Avatar
which header /s-pipe did you install?
Old Jan 13, 2008 | 02:32 PM
i installed the weaponr r header and s pipe
Old Jan 13, 2008 | 02:51 PM
bkuhl's Avatar
I would suggest checking the header support mounts I don't recall if there are two or not. If it's not that then it could be the secondart O2 sensor tapping or the s-pipe banging on the frame.
Old Jan 13, 2008 | 04:14 PM
i took those brackets out so i know its not that and it sounds like its the spipe banging on the frame
Old Jan 14, 2008 | 02:07 AM
mengsta's Avatar
Yeah Tc Pete had this too, he just took a bar and pushed against the frame the spipe to give clearance, and it worked.
Old Jan 14, 2008 | 03:03 AM
REVOSOLDIER's Avatar
are you sure its not the engine noise u have...cuz i had just an exhaust and when i installed headers is sounded like something was vibrating around 2200-3000 rpm i dont know exactly y its so raspy but i guess just cuz its a 4cyl maybe this will help idk.
o ya i put mine on alift and it wasnt hitting anywere.
Old Jan 14, 2008 | 03:14 AM
Crippie's Avatar
1UP Crew
id be willing to bet its the s-pipe hitting the passenger side crank shaft. if you can get under the car, look right after the spipe connection to the header, and see if theres a metalic stripe right above the spipe. if so, its rubbing on the crank.
Old Jan 14, 2008 | 03:18 AM
mengsta's Avatar
Crank shaft? isnt the crank shaft inside the engine?
Old Jan 14, 2008 | 03:19 AM
Crippie's Avatar
1UP Crew
the rod that comes out of the tranny on the passenger side. thought that was the crankshaft
Old Jan 14, 2008 | 03:28 AM
pioneer1976's Avatar
no what you are talking about is the axle shaft, the crank shaft is in the block
Old Jan 14, 2008 | 03:29 AM
Crippie's Avatar
1UP Crew
there you go.. the axle shaft.. thanks pioneer
Old Jan 14, 2008 | 03:35 AM
np, i dont have the weapon r but i think i remember reading something about the design of the s-pipe causing a noise and they redesinged it.(could be mistaking)
Old Jan 14, 2008 | 03:51 AM
Ok i just did a search and found someone that had a similar problem, You need to put the car up in the air. and check on the s-pipe were the O2 sensor is. Since your runnig a header and a s-pipe, the s-pipe has a cel eliminator on it. Double check the space between the O2 sensor and the rack and pinion. Check that and let us know what you find... You want to see a gap of at least 3/4 to a 1 inch.
