A/F Ratio gauges?
A/F Ratio gauges?
Im looking to buy a A/F AutoMeter cobalt gauge and wanted to know how hard they are to install. The prices I have found are around $370, but I have never purchased a A/F gauge. I have a cam con on the way and want one of these. Is $370 a good price for one of these A/F gauges?
If you have any mechanical and electrical experience you will be fine, if you can install a car stereo you will be fine. My AEM has a power and ground then you just route the other wires through the firewall. It will come with instructions.
I believe the AEM UEGO's are a bit cheaper than the Autometer stuff. MSD also has their Lazer line out. It uses a Innovate LC-1 as the actual wideband. Comes with the gauge, but I believe it's like 60mm.
I have a LC-1 in my Evo, and the thing works great. I use it to log through my laptop directly. You can also get the Innovate LC-1 and get gauges for it as well.
www.innovatemotorsports.com
As for installation, they should all be fairly easy. You'll need to drill into your exhaust pre-cat. Weld on the O2 Bung... Wiring should consist of a couple wires for power etc...
any diy for this gauge? also, you have to drill a hole somewhere and there has been some debate where the best place is to get the best readings for the air/fuel....any suggestions?
SloTC1
08-16-2018 02:45 PM
BlingSlade
10-19-2016 12:39 AM
