Freshly Rebuilt motor misfiring..
Just bought a rebuilt motor and put into my 2008 Scion tC. I've replaced most Parts along with the motor but I am getting a misfire on All 4 cylinders and it is not running properly.
I've replaced the throttle body, the mass airflow sensor, spark plugs and I'm about to replace the ignition coils. Can anyone else suggest anything else that I might be missing? *Moved to Correct Forum by Administrator Sticky Where to Post Your Question ______________________________ |
What diagnostic codes are you getting?
Is the "Intake Air Temperature Sensor 1" same as MAF sensor?
I would I think that it is the same because that's the only sensor I have on my air intake
https://cimg9.ibsrv.net/gimg/www.sci...81eec4fe7c.jpg
P0301= Engine Cylinder 1 is Misfiring. P0302= Engine Cylinder 2 is Misfiring. P0303= Engine Cylinder 3 is Misfiring. P0304= Engine Cylinder 4 is Misfiring. _____ |
Well for now I will try the ignition coils when I get them in and we can go from there.... I will check the intake manifold to make sure it's all tight.
Update.... still misfiring after the new ignition coils. And I did not notice any kind of leak on the manifold and checked all bolts. I am at a loss right now and the next thing I can think of is the injectors or the fuel pump.
Is your replacement MAF sensor OEM or aftermarket?
It is a OEM Denso sensor.
Did you check the engine coolant temperature sensor? A faulty one might tell your ECU the engine is cold when it's actually hot.
Originally Posted by TimsScion07
(Post 4294634)
... will check the intake manifold to make sure it's all tight.
Smoke the intake. I had issues that couldn't be seen after rebuilding our engine and it ended up being a crappy intake manifold gasket leaking air. Found the problem in less than an hour and put a felpro gasket on it.
Well I went ahead and changed the intake manifold gasket as it seemed cheaper to start with. Didnt see much change in the running of the motor.... going to change out the purge valve next and keep going from there.... eventually I will change out the right part lol
