Got my nitrous in
Now i just have to wait till i get money for dyno time and ill be spraying.
Hidden lol
fogger
bad solenoid pic
purge solenoid
fuel and nitrous solenoids
relay
working on the floor cover to make the bottle visible
bottle
pressure regulator
Hidden lol
fogger
bad solenoid pic
purge solenoid
relay
bottle
pressure regulator
Originally Posted by AcidDrop
you said that your gonna dyno tune it correct? show us some numbers once you get that done and also how does the car feel when you click the nitrous.
Yeah, you'll feel it kick pretty well, especially in the low end torque department.
You'll probably need a new clutch soon, so start saving up. I squeezed my SE-R and stock clutches don't hold up well to the added torque.
If you really want the kit to go un-noticed, paint the solenoids and other parts black. You might want to paint the relay too, that NOS logo kinda gives it away. Otherwise, good job on hiding the parts.
Originally Posted by tCyoung1
my stock clutch is still holding strong and i'm about to push 50k. i put the kit in when i just clocked 38k last year and haven't had a clutch problem.
i think i went through about 4 or 5 bottles last year. i would go to the track almost every Friday from march to September on drag radials and the stock clutch has handled it like a champ
nice, what times have you ran on and off slicks? on what bottle pressure? Just trying to get what I should expect since I have pretty much the same mods as you, if you know your hp rating Id love to know what to shoot for.
really? with spray? what rpm are you spraying in and how many gears cause I ran a 9.5 off spray at our 1/8adn I got a friend running 9's flat on slicks what you keep your bottle pressure at?
i try to keep bottle pressure 250 - 300 psi but i don't have a heater. but our local track here is garbage. they don't do any type of track prep and i still spin violently with drag radials. i have mine set to come on at 4200 rpm and cut off at 6400. the without nitrous i have ran 9.8 right now its down to just a traction issue.
my friends and i plan to go to the 1/4 mile and see what we can do there when the track is actually prepared. i know my times suck compared to yours. does your friends run full on slicks with a all motor set up?
http://www.dynotunenitrous.com/store...p?idproduct=17
thats the heater I got 99 bucks pressure regulated and a great company to work with
and our 1/8 is the same way it is called wilkesboro but proudly named slicksboro lol yeah full on slicks gutted rear and full bolt ons minus pulleys.
