Greddy Emanage Ultimate Help
Ok i have the Greddy Emanage Ultimate and i have it all wired up
problems
i have everything hooked up except water temp i have that channel hooked to the knock sensor and the other channel is hooked up to air intake temp
2: the knock sensor wont read any knock in the tc its supposed to have a new type of knock sensor that can read a range of knock but when i tap on the motor with a hammer it doesn't show anything? i have this channel set inside the emanage as a resonate sensor
is the sensor like the nissan skyline ones where u have to set the emanage to non-resonate and sent a frequency?
any help would be appreciated
thanks
problems
1: will not start the engine if engine is cold
2: cant get the knock sensor to read inside of emanage tool
1: when the emanage is pluged in and the engine is cold it will not start like it will kick over but not start, if the engine is hot the emanage is able to start the engine 2: cant get the knock sensor to read inside of emanage tool
thanks
So the report is that it now starts when its cold and seems to be working just fine i will report tomorrow after i have driven it around for a lil and as far as the knock sensor goes i seem to have it working the only problem is i dont know what frequency i should monitor bc i dont think the e manage can monitor more than one
Thank u paul
Thank u paul
So the report is that it now starts when its cold and seems to be working just fine i will report tomorrow after i have driven it around for a lil and as far as the knock sensor goes i seem to have it working the only problem is i dont know what frequency i should monitor bc i dont think the e manage can monitor do more then one
Thank u paul
Thank u paul
vi3tb0i09
Sep 23, 2015 08:32 PM
carid
Aug 31, 2015 11:17 AM
Subaru86
Jul 31, 2015 04:00 AM
