Head bolts stripped advice
So I went out and got a 12mm 12pt to fit my head bolts but I stripped them both out any Ideas on how to get these dang bolts out im so tired or doing this i just want it to end!!!!
Hey man, I had the same exact problem. What I did was went over to walmart and bought a stripped bolt socket. It worked PERFECTLY. I recommend heading over to a local hardware store and ask around until you find one. I think it was like $5
It comes with 2 bits...one to make a clean cone shaped hole in the damaged bold/screw. then you flip it around and it has an extracting head bit that grabs onto the surface hole you just made and pulls it right out using a standard power drill.
Ok here is a good lesson for those that do not know to get a bolt that is torqued in or in very tightly do not use a 12 pt wrench as the amount of surface space on the wrench is smaller than that of a 6 sided wrench,using a 6 sided wrench will greatly lessen the chance of stripping bolts.This was one of the first things my father taught me when working on cars,he was a mechanic for many years so I listened to everything he said,hope this helps others not strip bolts.
guys guys guys - its a 12 point INTERNAL head - not like a socket - hard to explain if youve never seen the bolt - using a hex head (otherwise reffered to as a torx bit) WILL strip the head of the bolt - you must use a 12mm 12 point internal wrench bit. He got the right tool second time around but it was already too late
Try the bolt extractor but those suckers are in there good - you may have to drill them out - done easiest on a drill press - you can take it to a machine shop to have them do this.
aha..........yes the torx would not be good to use for those,there are bolt extractor tools that clanp over the bolt and will leverage it out,not sure what they are called,but Sears used to have them.Torx are 6 points if i remember.....the 12s are a special bit.
But most of the time you are correct.
And you CAN use a 6 point on the head bolts, I can't tell you how many I've done that way. You just have to be careful and make sure you're straight on.
If you have the right tool you're better off using it, I only point this out because it's relatively hard to find 12 point bits like that, the 6 point are much easier.
I'm not correcting you to be an a$$, it's so you know next time.
You might have screwed yourself, depending how badly they're damaged.
Headbolts are high quality steel, a bolt remove might not work. Drilling will be a PITA [can be done though], welding a piece of metal might work, but there's a lot of torque on that bolt...
There's nothing wrong with doing things yourself, but sometimes it's better to take it somewhere to get done. :shrug:
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
LzeroKI
Apr 1, 2015 06:44 PM
