header
Old Jul 26, 2005 | 08:17 PM
seminoles68's Avatar
Default header
when you take off the factory header is the cat attached to the header and wont that screw up the emissions
Old Jul 26, 2005 | 08:57 PM
matty-tC's Avatar
the precat is built into the oem manifold.
yes it will "screw up the emissions"
Old Jul 27, 2005 | 03:10 AM
WeDriveScions's Avatar
New header means no pass on emissions, if they check like CA.
Here in Oregon, they just plug into the OBDII and if you have no CEL and a good O2 sim, it's really no big deal, unless they get nosey.
Old Jul 27, 2005 | 11:49 AM
is that the only cat on the car or is there another one
Old Jul 27, 2005 | 12:43 PM
matty-tC's Avatar
there's another one
Old Jul 27, 2005 | 01:10 PM
where is it located
Old Jul 27, 2005 | 01:54 PM
Whocares05050's Avatar
LOOK! walk out to the car, peak your head under the car and look. im not being an ___ but look and if you still cant find it then ask
Old Jul 27, 2005 | 01:58 PM
toastbox's Avatar
^^ or at least use the search button first.
Old Jul 27, 2005 | 03:23 PM
i have alright looked under the car and i do not see one. Every cat i have ever seen has a heat shield and i do not see anything under the car that has a heat shield
Old Jul 27, 2005 | 04:38 PM
solotc's Avatar
ok...its in the exhaust piping. its not hard to find. most cats are in the exhaust piping. if u read the first response to ur post, it refers to the cat in the header as a "precat". the reason it is called that is because it is before the main, or normal catalytic converter. just follow the piping with your eyes...and you should see the bulge of the catalytic converter in the piping of the exhaust
Old Jul 27, 2005 | 05:01 PM
matty-tC's Avatar
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
stayintrucha
Regional - Pacific South
Aug 27, 2015 05:01 PM
