Header CEL Fix
Old Mar 24, 2005 | 01:36 AM
  #41
nycazn79's Avatar
I ordered (2) 42009 and (1) 42002 and it turns out that each pack comes with 2 anti-fowlers in them, so now I have 2 extra pairs of 42009. If anyone wants, I'll sell it to anyone for $8 shipped via Priority Mail..
Old Mar 24, 2005 | 01:38 AM
  #42
Tc_Luis's Avatar
which one do u use, the 42009 or 42002? is there a diff?
Old Mar 24, 2005 | 02:35 AM
  #43
English's Avatar
Originally Posted by Tc Luis
so will this work on the megan racin header as well? will it also go on the s-pipe/downpipe?
It goes on the s pipe and it will work for every header that doesn't have a cat
Old Mar 24, 2005 | 02:43 AM
  #44
Tc_Luis's Avatar
thankx for the info i really appreciate it
Old Mar 25, 2005 | 08:39 PM
  #45
lvnurs9's Avatar
the megan header HAS a cat though...either way i guess it looks like it works
Old Mar 25, 2005 | 08:42 PM
  #46
RacerZack's Avatar
i have the megan header and i get a cel. i'll be doing this mod tonight, so i'll post in the megan header thread to let everyone know if it seems to work.
Old Mar 29, 2005 | 07:54 AM
  #47
DouBLeJ16's Avatar
i went to discount auto and saw the difference between these two. one of them (I'm not sure which number) is a little longer then the other. i used the shorter ones and it worked fine.
Old Mar 29, 2005 | 03:15 PM
  #48
davo345's Avatar
has anyone tried the resistor mod for the CEL?
Old Mar 29, 2005 | 04:56 PM
  #49
TurboTC's Avatar
Resistor mod will not work! Why would you even try when this mod is so easy?
Old Mar 29, 2005 | 09:05 PM
  #50
davo345's Avatar
just askin
Old Mar 30, 2005 | 05:36 AM
  #51
TurboTC's Avatar
Don't mess with your wires if you don't have to.
Old Apr 6, 2005 | 05:26 AM
  #52
DouBLeJ16's Avatar
I tryed this mod with the megan header and I still have the CEL.
Old Apr 6, 2005 | 01:14 PM
  #53
davo345's Avatar
not good...not good at all
Old Apr 6, 2005 | 05:02 PM
  #54
TurboTC's Avatar
Check your O2 connections and make sure everything it tight.
Get the code. This mod is only good for the "non efficient cat" code.
Old Apr 6, 2005 | 05:17 PM
  #55
Giravani's Avatar
Now now davo, let's not go and create more panic about this than there needs to be. This is the first time it hasn't worked for someone, and it's probably just something really simple that he missed. I would check all the bolts again, in particular the spring bolts. Make sure they are tight and compressed, if not, then you did something wrong. Re-tighten all the O2 sensors as well, also making sure that no wires are twisted too tightly.
Also, have you reset the ECU? Disconnect the negative terminal on the battery and leave it for 10 minutes. Might as well do this while you re-check all the necessary points of concern. When you're done, fire the car back up and let it idle for 15 minutes to give the computer enough time to check and adjust, and you should be good to go.l
Old Apr 6, 2005 | 05:38 PM
  #56
ScionDad's Avatar
Odds are ......he did the wrong O2 sensor. It's the sensor on the S pipe....NOT the header 02. The last guy did the wrong 02 sensor and one before that damaged his first 02 sensor when he removed it. This mod works
Old Apr 6, 2005 | 05:54 PM
  #57
motozen's Avatar
why are you selling your header dood?
Old Apr 8, 2005 | 04:28 AM
  #58
DouBLeJ16's Avatar
i put the anti-fouler's on the s-pipe, not the actual header. i reset the ECU and it hasn't come back yet (i drove about 20-30 miles)
Old Apr 8, 2005 | 05:35 PM
  #59
RacerZack's Avatar
Default &$#! CEL
OK, I finally did the CEL fix and it didn't work for me either. This is what I found:
1. The difficulty I had getting the s-pipe O2 sensor off was because the threads on the s-pipe were damaged. This caused the O2 sensor's threads to become stripped. I do not believe that simply attempting to unbolt the O2 sensor could have caused this. It appears that maybe some grit was on the threads of the s-pipe at the factory when the O2 sensor was installed. At least, that's the only theory I can come up with.
2. I cleaned up the s-pipe threads and carefully tightened the O2 sensor into the antifoulers and them onto the s-pipe. I put anti-seize on all the threads, too. I was able to get the O2 sensor + antifoulers tight, but i had to be gentle with it.
3. I did reset the ECU by disconnecting the battery for more than 10 minutes. I also let the car idle for 20+ minutes before driving after everything was back together again.
After 41 miles, the CEL was back.
So, here's a few questions...
1. I recall the s-pipe having some kind of screen or grating on at least one end. Am I imagining this? When I disconnected the s-pipe so I could work on removing the O2 sensor, I found that this screen is no longer there.
2. So, I'm on my back with a flashlight peering up into the Megan header. I can see all the way up to where the 4 pipes join to 1. I'm thinking "precat? *what* precat?" Shouldn't I have seen something within the air path which would be a catalyst for emissions? A regular catalytic converter has a mesh-like substance (metal, ceramic, whatever) that the air passes through. I saw nothing like this on my header. This has me puzzled.
3. I'd like to get the engine code and find out exactly what the CEL is trying to say. My tC is at the dealer today getting my first free oil change so I asked about getting the code. I was told it would be an hour's diagnostic labor @ $79! WTF is that all about? It's not going to take an HOUR to get a code from the computer. My only experience with engine computers is with my Miata. There is a driveway "trick" which allows me to connect two pins of the diagnostic connector, causing the check engine light to flash and return the error codes. Plus, Mazda techs can connect to the diagnostic connector and get the codes in a matter of minutes. Isn't the tC the same way, at least for the Scion techs???
I suppose it is possible one of the O2 sensors was damaged, but I didn't drop them or do anything other than set them on the table. I am sure all of the bolts (including the spring loaded ones) are tight and I did make sure to use the little "donut" which sits between the header and s-pipe.
Old Apr 8, 2005 | 06:02 PM
  #60
DouBLeJ16's Avatar
Default Re: &$#! CEL
you might want to take the car to a local autoparts store.. discount auto & autozone both give free diagnotic tests to see what code the car is throwing.
btw, in case anyone is wondering, I've gone about 50 miles since I reset the battery and the CEL hasn't come back yet.
