header torque specs?
This is all I came up with from someone installing DC header
<snip>
Since I did not have a torque wrench, I tightened the bolts to the point where I thought, "Yeah, it's tight." I've talked to a few mechanics and they do the same. But if you would like to tighten them to spec, the header bolts/nuts are 20 ft. lbs.
Once the header bolts/nuts are tightened, grab your socket wrench with 14mm socket and the spring-loaded 14mm bolts, then shimmy yourself back under the car. Bolt the spring-loaded bolts back onto the b-pipe and header. The bolts will actually stop turning, so listen to the "Jack-in-the-Box" music until they stop. Again, tighten until "it's tight." The torque spec for the spring loaded bolts are 32 ft. lbs.
<end snip>
<snip>
<end snip>
See, thats the problem...mis-information. Sorry for passing that. Figured someone would have called that before now on the old post.
Guess I need to add about 7 more pounds of torque....It's been a few 100 miles now. Can you do a sticky for all the torque specs for commonly modded parts?
Originally Posted by SCIONPARTS
exhaust manifold converter to cylinder head 44(N-m) 377(kgf-cm)
27 (ft-lbf)
27 (ft-lbf)
The 20 ft-lbf of torque you read about for the DC header install was for the xA/xB...
Wrencher
Mar 12, 2023 04:54 AM
Hydryman
Feb 23, 2016 03:35 PM
Subaru86
Jul 31, 2015 04:00 AM
