HELP! Cant get oxygen sensor off
Im trying to install a header but the oxygen sensor will not come off the stock header. Which way do you turn it to come off? We turned it left, then it felt like it was coming out but got tight again. Please help, I have no vehicle to drive for the time being.
well first make sure the car has time to cool down....it's a little harder taking off the sensor on a hot car haha.... um I usually spray a little PB blaster around the nut part of the sensor and let that soak for a little bit....but you just have to turn to the left and that's all....just make sure you unclip the connector otherwise the wire will just keep spinning back with the sensor
The size wrench to get the sensor off?? Its 22mm....
And sorry to say but yea it sounds like your sensor came cross threaded from factory, some tC's came with them while others didnt....
I have an 02 sensor socket I use that I got from snap-on but if you don't use it everyday you can get one from sears or something.... it's handy b/c the wire can go through it and you just need a ratchet and an extension to use it....makes things a lot easier
So what is the name of the sensor? Where can I get it? How much? Yes mine is stripped. It started turning left, and then got tight, and nothing. I soaked it, used the right 02 socket, nada.
Thanks dude, I have to go buy one tomorrow so I can put on my new header. I got everything else off and then blamo, sensor jammed. And to boot, I threw a cel even though the sensor never came off.
Mine came out like cake with the car warmed up. If it gets tight when you try to loosen it, Just keep lubing it and turn it back in, then out again till it gets tight, then back in, repeat. If the threads are not damaged this should get it out eventually.
vi3tb0i09
Sep 23, 2015 08:32 PM
gqdabien
Sep 17, 2015 09:23 PM
