help with major problem
Old Sep 6, 2009 | 05:33 PM
blackcherry07's Avatar
Originally Posted by ecko04
Why exactly would you need a new doughnut gasket? You can reuse it. I wouldn't have used WD-40 though, it is highly conductive. You should have used soap and water in a spray bottle.
I think he was just joking about the head gasket He went back and edited it to exhaust manifold gasket
i was worried that soap and water would evaporate before i got to see results...
and if its leaking this bad you think i can still re-use it?? how do i make sure that it makes a reall good seal....both of the spring loaded bolts are very tight and its still leaking...do in need to adjust something??
and i see that now...
Old Sep 6, 2009 | 06:20 PM
ecko04's Avatar
Look at the gasket...is it mushroomed? Is it split? Does it look damaged?
Those spring loaded bolts can be a PITA to actually get tight so are you sure they're tight. Are you pushing up on the s-pipe to get that good seal while tightening the bolts?
Old Sep 6, 2009 | 06:27 PM
ill have to check the gasket out...i dont have the time today to...
the bolts are tightened to the point where the springs are almost fully compressed....but i didnt push up on the s-pipe while tightening....that could be my problem...do you think if i loosened them and then pushed and re-tightened with-out fully removing it would accomplish the seal??
Old Sep 6, 2009 | 06:35 PM
ecko04's Avatar
You don't have to take it way off. You can tell if the gasket is split by loosening it. Just check the condition of the gasket because it can slide, in which case now you have a split gasket.
Old Sep 7, 2009 | 03:46 AM
gasket must be screwed i couldnt find any other signs of anything else being wrong...
also it WILL NOT rev above 4k...i can pull out and pedal to the floor in 1st and it just gently stops at 4k...
Old Sep 10, 2009 | 09:52 PM
My second cat was totally clogged...
removed it and replaced with pipe and the car runs BEAUTIFULLY...
RY_TC07
Jul 18, 2017 05:18 PM
excessads
May 14, 2015 02:18 PM
AxRxP
Jan 18, 2015 05:43 PM
TheTripleC
Jan 4, 2015 06:46 PM
Opr8r
15
Oct 6, 2003 05:07 PM
