Heres a fun one to diagnose...check it..
Well....here we go. I will give all the details i can and answer what i can before it is asked.
05 scion tc. Original owner. 322,000 miles (yes, 322,000). No mods at all. Replaced all 4 coil packs and plugs about 6 months ago. Old ones were arcing.
Symptoms....severe hesitation with anything more than 20% throttle. Audible clack-clack from under hood that IS NOT rpm dependent. Meaning at an idle it is not heard, acceleration it is heard, cruising it is not heard. Very weird. Gas mileage has not been affected at all. I drive with my cruise control on and it drives normal, until a hill comes and it hesitates.
Check engine lights?? Yup. Misfire 1-2-3, cylinder lean, cat converter code.
Starts up fine. Idles perfect. Cruises perfect. Loud clack clack from under hood.
It is not a spun bearing. The oil is perfect and i have put about 500 miles on it since it started.
My guesses are....
1 valves are so far out of spec and need to be adjusted.
2..bad camshaft timing gear
3..stretched chain/faulty tensioner
4..bent valve(highly highly unlikely. I never ever beat on it and havent missed any gears)
Tommorow afternoon i will be taking off the valve cover and checking the clearances...any guesses before i proceed??
Anything is much appreciated!
My guesses are....
My guesses are....
My guesses are....
After checking the clearances im very confident it is the tensioner/chain. I think the tensioner broke and the belt has slack so it has either skipped a tooth or is so loose its doing whatever it wants. Should be fun/cheap to replace. Boooooooooo..
Btw...car still drives and iv put 1000 miles on it since this started...stupid? Sure. But how cool is that? Lol
yeah i was gonna say if your gonna go through pulling the motor or how ever you plan on getting into the chain and tensior you might wanna get some work done to the motor if your planning on keeping the car
BlingSlade
09-05-2015 08:52 AM
