Home Depot tC pulling a p2195, power cutting... Help!
Hey guys, newbie to the board, newbie to the tuning world, but not a newbie to general messin'-around-with-stuff-until-it-works. I have an '05 manual tC that I bought used with 40k miles, and I've put about 20k more on it since I had it.
I've finally decided to start working under the hood to crank up the power. For better or worse, I enjoy doing everything myself, including building my own frankenstein'd car parts... So far I have thrown together a CAI/ram air system out of a cheap intake kit, some drainage hose from Home Depot, and some PVC pipe adapters...
That was fun, so I went on to buy a used Megan header and threw it on. Yes, I remembered all the gaskets, etc.
A friend recommended I put in that elbow/snorkel sort of thing for the O2 sensor to keep the CEL from coming on... but it still does. I can feel the power drop out of the car for a split second sometimes when I floor it in 1st-3rd gear.
My CanOBD2 informed me that the CEL is reading a p2195: O2 Sensor Signal Stuck Lean Bank 1 Sensor 1.
I'm assuming my computer just doesn't know that it needs to run a little bit richer now that the engine doesn't have to work quite as hard to pull/push air through it. Anybody know a quick fix? I really don't want to dump 500 bucks on a fuel controller, but I don't want to just 'fake out' the O2 sensors so that the CEL goes away.
If it means anything, I also threw in a breather filter, and there's a nerf gun in my glove compartment. Everything besides the intake/ram air/exhaust manifold is stock.
(I searched around for other threads about this sort of problem but I couldn't find any. Sorry if I missed something obvious!)
Thanks a lot in advance; I appreciate the help!
Biscuits
P.S. I know some of my methods look a bit sloppy, but hey, if it works...! I like to think of my car as a bit of a modern rat rod anyways, haha.
Biscuits
wow! lol that elbow thing to remove CELs is possed to go on the secondary o2 sensor which is the one in the spipe, that pipe under the oilpan not on the header o2 sensor.....switch it up and ull be fine
Wow, I am a fool and a half! Ahahaha, thanks much... woops! I'll get back to you when I've done that... lmao.
after switching it up unplugged the battery for 30 seconds to clear the ecu of check engines and fuel trims.....then plug battery in and turn key to on position for 5 seconds, then turn car on and let it idle for 5 minutes...this will giv eu idle fuel trims and make the ecu start making fuel adjustments according to your new mods
Thanks so much... ahaha that's embarrassing. .___.
Sorry for the double-post... I was out there looking at everything, and there is no way I'm going to be able to get that huge L shaped thing screwed into the port for the O2 sensor on the S-pipe; there is not enough room to swing the whole thing around to screw it in... do I need to take the entire S pipe off to put the L shaped thing on it? Or should I just get that anti-fouler thing for $6 everyone talks about?
i dont think you need the anti-fouler. i had the megan header on my car and didnt install the antifouler on the s-pipe and did not get any CEL.
if you do plan on installing the antifouler, you'd need to take the spipe off to install it, there isnt enough room to screw it in while on the car.
Hmmm... Alright, I will take the L piece off of the manifold and put the sensor back in, then try letting the car idle for a few minutes to set the fuel trim like cburglb34 recommended. Maybe I just wasn't letting the car adjust the trims, and that's what's been giving me the error. Thanks guys.
its a crap shoot, some get a cell and some dont. i used two spark plug antifoulers from home depot with a hole (cant remember what size) drilled through the second one as a cel eliminator. Like martin said, run it without the anit-fouler on there. If it still throws a code, take the s-pipe off and put it on, and if it still throws a code after that, try what i did!
For the antifouler trick it works..I use to have DC header on my setup and it works, also I still have it for my turbo setup..check out this tech article:
https://www.scionlife.com/forums/tc-tech-diy-1818/header-install-dc-sports-22180/
yes u will need to remove the spipe its easy....then install the fouler(L thing) in there
by having the L in the header u were risking serious damage to your piston rings...
the o2 sensor on the header is a AIR FUEL RATIO sensor that tells your ecu wheter or not its getting the right amount of air to fuel ratio, having the L in there was prb making the sensor read more air than fuel thus making the ecu dump alot more fuel than needed, which in turn fouls plugs and washes away your piston rings
