How easy can it be to achieve 200 whp?
How easy and, expensive/inexpensive would it be to gain just 200 naturally aspirated whp to a tc. What parts would be involved in this process? Also how much of a difference would I notice/feel driving a tc with 200 whp vs. the stock 160 we are alotted? Feed back would be appreciated....
search, there is a nice long thread about it
edit.
found a thread for ya.
https://www.scionlife.com/forums/viewtopic.php?t=111169
enjoy and good luck
edit.
enjoy and good luck
Cold air intake, Header, Exhaust, Lightweight crank pulley, ZPI High compression pistons and Stage 1 head, Engine management, Bigger throttle body, Lightweight flywheel and performance clutch. You would definately have 200 whp. You will have a lot more available hp across the entire power band. Keep in mind the stock is rated 160hp peak at the crank, so if you are pushing 200whp you have around 60 more hp to the wheels then stock. There will be a lot of money involved probally around 3,000.
My goal for hitting 200 is....
What I have : D/C Headers, Injen CAI, Greddy Evo II Exhaust
What I need: Stage 1 Head, 11 compression pistons, Pulleys.
Not to sure if I would need a throttle body although I can't find one....
Which engine management set-up would you prefer?
vi3tb0i09
Sep 23, 2015 08:32 PM
