How much time does a short shifter save in 1/4 mile time?
Depends
Somepeople do better some don't after installing the shortshifter.
If you can save .01 seconds. a hundreth of a second your car starts putting power back down. Since we have to shift 4x in the 1320 you potentially could save .04 seconds or more.
the feel is great - it makes driving better. The overall time savings ...well.... I wouldnt get this mod if you are looking for a performance gain because the throw was long but you arent driving a UPS truck.
It makes you faster in the sense that you'd get across the line quicker snatching through the gears than you would missing a gear
I just installed my TWM stage 2 shifter yesterday and so far have only had 1 day of first hand experience with the shifter. The only advice i could give is get a weighted shift **** too. Gears require a little more "persuasion" with a shorter throw/height-- just like a fulcrum, (balanced see-saw)-->Move the midpoint closer to any given side and the shorter side requires more weight to lift the opposing side.
Originally Posted by filmnews
I am currently running about a 10.28 in the 1/8th mile,. Does anybody have an dea on how much time it might take of my 1/8th mile time?
what would help significantly is replacing the dumb drive by wire system which has a VERY noticeable delay when quickly closing and reopening the throttle plate between shifts. I read an article on the Acura TSX which also has this issue. Just by powershifting (keeping the gas pedal depressed while shifting) they were able to shave nearly half a second of 0-60 and 1/4 mile. However I would strongly recommend against doing this.
https://www.scionlife.com/forums/vie...=84643&start=0
NonStopTuning
Jun 29, 2015 07:42 PM
