Hyper Voltage System
Does any one know if these do anything at all for the Scion.
http://www.intakeone.com/Denso/SunHVS.html
any help would be great
hnefrdo has the Pivot brand voltage stabilizer and he swears by it. He said he noticed a difference, and so did his sister's boyfriend (when he drove the xA)...
I'll probably get the Pivot Raizin kit, as well...but later down the line. A voltage stabilizer with ground wires is a good combo. :D
I've got the Sun Voltage MR system on my xB w/ a ground kit by Ground Fusion. Probably not getting any hp (perhaps one horse) out of this setup, but I noticed better throttle response and smoother idle. Where it may be helpful is if you are taxing your battery and then start to demand power at higher rpm. Its sort of like a battery reserve (like a cap for an amp).
Originally Posted by Resolve
Thanks guys.. I will also check out the Pivot.. wasnt expecting HP to much just wondering about the throttle response and fuel economy stuff
All I have is my "Mikochu Über Ground Wire System (v2)" right now. I took my v1 ground wires off and noticed erratic idle and the throttle was not as responsive as with the ground wires. My v2 ground wires was optimized to 4x8 gauge wires (v1 was 6x10 gauge wires) and it does the job. Idle is smoothened out and the throttle is much more responsive. I probably won't buy a voltage stabilizer until I have money to burn...but I'd make/install ground wires first.
I don't have plans on selling my kit, but I encourage others to make their own. I had some wire left, so I made a kit for TakumiJr and Kara. I won't be able to get Kara's kit to her until later this weekend, but TakumiJr got his and he says they really made a difference on his auto xA...
With the fuel economy, I don't think you will notice a difference... *shrug*
Finally, I finished making the hypervoltage systme myself!, on Thursday :D It costs me about $30-40. Parts are from Digikey and radioshack.
I connected it to battery. And the results......
My car is quiter, has less vibration and respond faster. It shifts more rapidly. I am fully satisfy!. Lights are also a little brighter.
ECU also need to learn about this mod to adjust some parameters for a day, I guess.
However, I feel "little" change in power at steady speed. I will post some pictures soon.
If you guys are interested, I will write it up in more detail.
TheTripleC
Jan 4, 2015 06:46 PM
kagero79
57
Nov 14, 2008 01:25 AM
