Injen Cold Air Intake Clicking/Chattering Noise HELP
Ok so i installed an Injen Cold Air Intake Around... August and now it is October, The Weather in now near it's 30-40s. I've never heard this noise until now. Its coming from the Vacuum Switching Valve (VSV). I've been lookin at some other threads but they dont give me a straight answer... could anyone help me? is this normal or not?
yup its rubbing on the frame. did you put that rubbing thing that youre suppose to put on the frame so you cant hear the rattle when it vibrates? my intake came with one and it helps eliminate the rattling noise.
Originally Posted by fiendskillz
maybe the cai is rattling with the body frame from where you put the tube out from.
lol guys i know my CAI rattles and all, but i specifically said the Vacuum Switching Valve is clicking.... but thanks for the link to dr. isotope, i will definitely get that now. back to the "VACUUM SWITCHING VALVE (VSV)" anyone?..
doesnt seem like it, i think i may have solved the problem, just took some stuff off n cleaned it n then reseted the ecu.. now its quiet again... except for the CAI... RAWR!
if u listen closely to the Vacuum Switching Valve it should click, almost everyone says its normal, the VSV is the thing with the green cap on it.. but now i have a different problem, when im inside the car i think i hear my CAI rattling.. it never did that until now..
it ticks to control warm idle..
it's normal.. don't worry about it.
as far as rattle.. check to see if anything is loose.. open up the hood and wiggle it yourself... see if it is hitting against anything
it only does it when im in drive so dont know whats moving, but i do know that theCAI rattles... so im just assuming that, but i've never heard the thing rattle from the inside of my car until now..
