Installing magnaflow exhaust, instead of cutting behind the cat, get an s pipe?
Old Aug 20, 2009 | 01:00 AM
Jlowe's Avatar
Default Installing magnaflow exhaust, instead of cutting behind the cat, get an s pipe?
I'm a little confused, i've searched and found out that the S pipe removes the second cat.
http://www.planetmagnaflow.com/pdf/16640.pdf
is the instructions i'm using to install my Magnaflow catback exhaust.
Just a question though, instead of cutting 3.5" behind the cat, can I get a, let's say invidia or megan s pipe, and then just clamp the midpipe without cutting to the spipe?
Or am I completely wrong?
Oh, and this won't throw a CEL will it?
Old Aug 20, 2009 | 01:04 AM
Jlowe's Avatar
Alright, sorry, I found my mistake.
Heres a quote from another forum
An to correct an earlier comment, the S-Pipe does NOT contain a catalytic converter. The secondary cat is located at the head of the Mid-Pipe. The S-pipe is usually separate from cat-back kits and only part of one header system that I know of. Yes, the S-Pipe is the most restrictive component after the header. Correctly built S-Pipes do not throw a MIL (Malfunction Indicator Lamp). Replacing the header with one that does not have the primary cat will.
So it's at the tip of the stock midpipe. Will I still have to cut before the cat? Even with an aftermarket s pipe? Seems stupid that I would have stock header, aftermarket or stock s pipe, piece of the stock midpipe with cat, magnaflow midpipe, muffler.
I'm just really confused, someone want to correct me?
thanks.
Old Aug 20, 2009 | 01:39 AM
elcapetan's Avatar
its before the resonator on mid-pipe. just take both off and put aftermarket in. you have stock header you are ok for emissions.
Old Aug 22, 2009 | 04:50 PM
imsonofagun's Avatar
The magnaflow is the only cat-back that keeps the factory catalytic converter on the mid-pipe. You would have to get a custom piece made to remove the cat in the mid-pipe. Another option is to get a different mid-pipe (Megan Racing), but then you'd have to cut/weld the Magnaflow exhaust to mate up.
Something else I didn't like about the Magnaflow system is it uses different size piping (almost 2.5" in one section, back down to 2.25" in another). The Megan mid-pipe would resolve most of that though, but as I said above, would require cutting and welding.
If you look at most cars on the market, the catalytic converter is setup a little different than on the tC. Most other vehicles have a flange directly after the catalytic converter on the mid-pipe. The companies that sell cat-back exhausts sell the section that bolts up to the flange on the catalytic converter (hence the name cat-back (from the cat to tail pipe) exhaust). Since the flange after our catalytic converter is right before the muffler, we have axle-back exhausts, which some companies consider cat-back exhausts. Other companies that replace the full mid-pipe call their exhausts cat-backs, but are technically down-pipe back exhausts (the s-pipe is normally called down pipes on other vehicles).
Old Aug 23, 2009 | 12:45 AM
my06tc's Avatar
it would be so much easier if the tc's had removable cats so we dont have to get custom midpipes done....but im sure we can do that ourself put a flange at the end of the cat
Old Aug 23, 2009 | 05:40 PM
User 112921's Avatar
would getting a megan s pipe do much? like make it louder, any slight gains? and anyone know how much a new one is?
helloninja
Mar 19, 2018 04:50 AM
Squishface
Sep 15, 2015 06:51 AM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
Hardhitten
Nov 6, 2003 05:23 AM
