Megan Stainless Steel Header.
I wonder if these headers will work with the supercharged engine :D?
Really the megan headers sound a lot better in quality than the DC. The bad reviews about the DC headers and the exhaust note it creates makes me uneasy, which is why I am gravitating toward megan since it doesn't alter the exhaust tone in such a negative manner.
I'll probably swap them out and put the stock ones back on. I can't stand the noise.
from what I understand, if you let the megan headers break in, the DC sport header annoyingness goes away. Meanwhile, the DC sport headers just keep the same raspyness even after being broken in.
I put this header on my car yesterday, I was kind of shocked how they didn't include any bolts at all. The bolts on the brackets are connected to the stock header so you have to find & purchase your own bolts.
Also, when I bolted the megan header to the S-Pipe I noticed that it didn't seem completely air tight. Everything did line up, and the bolts did turn until they were very tight.
I had my friend go inside the car and rev it up a few times and I noticed that I felt a small ammount of air come out where the header connected to the s-pipe. I was wondering if this is normal or not?
I really don't see any other possible way to connect the header to the s-pipe because the holes & bolts line up perfectly.
Any advise would be great.
You have to be careful when you tighten down the header flange to S pipe that the bolts with the springs actually go in right. If the springs don't compress, then the tapered bolt is not seated right. Also the obvious exhaust gasket everyone is talking about (doughnut looking thing to S pipe).
The header will change sound after a month or so (a few 1000 miles).
I changed out the TRD exhaust for the original stock last night and the sound lowered alot. I'll drive it around for a while and see how it sounds.
Originally Posted by DouBLeJ16
I got the problems fixed with the exhaust leaking. I forgot the gasket by mistake.
I have the spark plug anti-fouler's installed correcltly and still got the CEL.
kslim619
Sep 18, 2015 06:54 PM
