Mishimoto 2 core aluminum radiator installed and review
#81
I just installed my gates 170 degree thermostat and it works amazing with the mish rad and my fan setup.. I cruise now usually between 177 to 184F! even with a watercooled turbo setup..
#84
Originally Posted by Carlanga
Ace, did u figure out the question u had about the mark in the thermostat itself? I can't find the thread.
http://scionlife.org/Scion_Docs/2005...at/x040001.pdf
no never found out what its for, someone said its to get air out of the block. not sure if its accurate though.. the gates thermostat didnt have one so i dont think its something really very useful
#85
question so the drain plugs ......... are the plugs bad or the rubber o-ring around it? im ready to install radiator and thermostat but i could not find a drain plug to fit radiator thinking it was the drain plug i had to change, or is it just the rubber ring ????????
#87
OMG i thought it was the drain plug it self , i noticed that when you screw plug in the rubber gets smash by plug and radiator walls so im just going to used the stock ones then and do what you did .......... thanks
#90
none of them have it, i did the same thing when i saw the leak. i contacted mishimoto and they sent me a new set but only one set, i needed two. i compared the plugs and they were identical. the only difference was the o-ring, the one i had was junk.
#91
lol if i install it and i get leaks im just going to put metal screw on the top and the bottom and call it a day .......... ahhhh all night looking for plugs anyways im doing work tonight .
hampton1100
05-28-2015 07:32 AM
TheRedBox
31
12-02-2003 04:53 PM
