MMW HEADER....MISSING GASKET?
Old Jan 15, 2008 | 01:03 AM
Wubbarican69's Avatar
true, but my point is expressed in that you can get a ____ load more power if you were to go with a turbo...rather then spend the money like i did.......as far as the mid pipe question i re-did everything from my headers....all the back to the muffler. all stainless
Old Jan 15, 2008 | 01:04 AM
svencarlson07's Avatar
or u can do all that and go s/c and get good results and keep ur warranty
Old Jan 15, 2008 | 02:56 AM
curtislo9's Avatar
TCpete, I have a 2.5" midpipe with a resonator. I loved it once I slapped that on my car. It's definitely noticeable and makes the car a bit louder.
Old Jan 15, 2008 | 02:58 AM
curtislo9's Avatar
My question still is unsolved, how do I stop the rattling?!
Old Jan 15, 2008 | 02:59 AM
im going with a vibrate stopper material to wrap around the spipe where its close to the frame and see if that stops it
Old Jan 15, 2008 | 03:06 AM
curtislo9's Avatar
Hmmm. post your results. That may cure it!
Old Jan 15, 2008 | 10:34 PM
mengsta's Avatar
Hey Pete i thought you stopped the rattling? ALot of people just tried to bend it to give ot clearance.
Old Jan 15, 2008 | 10:57 PM
cee_dub2003's Avatar
pictures please. We need to know what you are all experiencing. We have done a few install here and have had no problems what so ever with clearances on anything .
Old Jan 16, 2008 | 02:43 AM
rolloutrs1's Avatar
has anybody gotten a cel after install? mine came on a day after installation and when away after a day or so. this morning it came back on and im hoping it would go away again.
Old Jan 16, 2008 | 03:05 AM
mengsta's Avatar
Are you using the CEL eliminator?
Old Jan 16, 2008 | 03:26 AM
rolloutrs1's Avatar
^yes i am.
Old Jan 16, 2008 | 03:59 AM
mengsta's Avatar
WAaattt thats weird. check the connections? iono, sum1 with a MMW longer please chip in on this.
Old Jan 16, 2008 | 04:11 AM
sako's Avatar
hmmm u could get a s/c along with the mmw header setup but ul have to keep the stock intake... or if u really want the 5-10hp the injen cai gives u... ur gonna have to spend a lot more money on a piggyback ecu... in other words get turbo (zpi stage 1 gives u great #)
and the s/c mmw and s pipe u can pray for 220whp!!
Old Jan 16, 2008 | 04:12 AM
Aroddalobster's Avatar
maybe the 02 sensor got F***ed up when you were either taking it off or puting it back on. not sure...
Old Jan 16, 2008 | 04:28 PM
Our CEL eliminator is adjustable to a certain extent. It does matter how far you thread it into the SECOND O2 sensor bung. Try rethreading it a little bit out then lock it wit hthe large nut. Then reset the ECU, and try that .
Old Jan 23, 2008 | 09:42 PM
curtislo9's Avatar
So I just got under my car to tighten the bolts holding the header and s-pipe together to try to stop the rattling noise, but it didn't help. My pipes aren't touching the frame of the car either...so I don't know what could be the problem... Any help?
Old Jan 24, 2008 | 12:37 AM
mengsta's Avatar
I got a weird rattling noise too, Its not necessarily as loud as a metal to metal rattle would be, Its kind of a unique rattle? like lil small metal peices are shooting out or something right? lol
Old Jan 24, 2008 | 01:35 AM
curtislo9's Avatar
Maybe like little shavings of metal that are inside a container that is being shaken? I think we are experiencing the same thing. Any yeah, no pipes are resting against the frame either...
It's occurring between the header and s-pipe connection (I went under the car when it was up on jack stands while it was on to figure it out (I know it's dangerous, but I was desperate haha))
Where is your rattle taking place?
Old Jan 24, 2008 | 02:40 AM
mengsta's Avatar
I do that too, i just make sure i have jack stands. mine is yeah between that connection. It is NOt rattling against any kind of metal frame or anything, weird huh? And it cant be literally metal shavings if this rattle has been going on for about 1k miles for me. Pretty weird. i mean its bearable. it also comes back wen i drive till 3.5k rpm.
Old Jan 24, 2008 | 04:46 AM
curtislo9's Avatar
Hmmmm. I can't really here it because by the time I'm at 3.5K im going at WOT hahahahaha. But yeah, I think we are experiencing the same thing, I'm glad I'm not the only one. I think that the type of bolts we are using may be the problem...
Is your exahust gasket/doughnut thing covered all the way by the s-pipe? Because mine isn't.
