More Power! Looking for pro advise
I have an '09 tC manual transmission with the Injen cold air intake 3" pipe. I'm looking for some advice on what else to do to my car with 1 main concern, more power. Of course I want it to sound good too, that deep bassy rumble. Any recommendations for exaust system setup or anything else to increase power short of a turbo (too expensive) would be appreciated.
Originally Posted by CarbonXe
Boost.
buy a good header and make the rest your own.
Run 2.5 inch tubing for that low rumble. Aluminzed steel will be the cheapest and thats what oem uses so dont worry it wont rust in a week.
Why does everyone by brand name tubing? the gains will all be in the same general region no matter what brand you buy. Just get the specs of your favorite sounding exhaust, get a guy who can bend and weld and your done. Buy a nice high flow cat and get a resonator delete if you don't mind raspy exhaust. otherwise replace the resonator with another high flow cat and it will sound very very very low and still offer good velocity.
maybe in the south its easier. A case of bud red and like 60 bucks at most and the guy will bend and weld till it works.
boost..... i had everybolt on header/intake/catback didint have a pulley kit tho all in the end all that money i wasited coulda got towards boost now i wasited 1k+ on boltons just got boost and be done with it
so its sounds like the general concensus is to just bite it and boost it. where can i get some additional information about where/what to buy. Also I prefer doing all the work myself, im not too technically advanced in automotive work, but I always take a shot and get it done right. Should I get it put on professionally or could i do it with a read through and a day?
If you have or know anyone with the space and tools do it yourself. Could be a great learning experience.
But yeah like everyone said if power is what your looking for a turbo kit is the best way to achieve bigger numbers.
So my knowledge on the subject is limited to put it nicely. Supercharger or turbo? what the difference? Which turbo should i get and where? And Im assuming the CAI has to come out for the intercooler? Any in-depth links or posts would be awesome
Well even though I don't own a TC i know that money wise a turbo is your best bet.
Superchargers are reliable, but you wont get much power compared to a turbo. The stock block can easily handle 280hp/tq and is know for up to 300whp without blowing up.
Now if you like the fact that a supercharger can be under warranty since you can get it for $4000 bucks at the dealer LOL
But its up to you!
But its up to you!
TRD supercharger is still available - actually work at a scion dealership and asked the parts department for a price and $4,000. Just turned around and walked away. Anyone have any good websites for ordering the turbo?
Lol I cant beleive I guessed the price. I should go on the show the pric is right haha.
Here are good websites...
http://www.turbo-kits.com/tC_turbo_kits.html
and for a cheaper non plug and play, dyno tune required (also with the kits above) kit...
http://www.fueledsports.com/grtukit1sctc.html
Estimated 100whp increase for 3k. Not bad at all.
Now the good kits (first link) should give you alot more power to play with, and they wont be stressed as much.
Ohh,
Btw...the best bang for your buck, with ALOT of room to play (480whp with built motor down the road) is the Turbo Toyota's kit.
Now if you can find it cheaper go for it, but this kit is designed to spool on a dime.
Good luck
Ohh,
Good luck
before doubling you hp with a turbo, maybe think about some small mods to make sure that power actually gets to the wheels? For less than $60 bucks for the kit you can get the energy suspension polyeurethane motor mount insert kit.
I did the install myself, I reccomend paying to have the mounts pressed in, it wasn't easy. but afterward the respone was great, no more engine torquing the mounts and jerking, the power goes straight to the wheels, next to none on the wheel hop as well, and it doesn't sound like crap like the torque dampner.
Ohh,
Good luck
Ohh,
Good luck
Turbo Toyotas may I warn you has a list of ppl who have been waitin for their kits for some time so be weary...
I would go with Ptuning kit (F'n amazing) or even dezod
