My cel keeps coming on.
Old Sep 19, 2005 | 12:47 PM
XD40tC's Avatar
Originally Posted by Souljah347
which o2 did you use the antifouler on. it needs to be on the s-pipe i think. someone correct me if i'm wrong
You are not wrong but if you were you would have been corrected before you even posted.
Old Sep 19, 2005 | 12:49 PM
XD40tC's Avatar
I tried to drill all the way through one of the anti-foulers but I only had the strength and patience to get halfway through it so what I did was check to see if the sensor fit and it did but I had to lightly bore out the inside walls. I think that probably decreases the amount of flow the sensor receives too because basically only the top hole of the sensor is exposed to airflow. I used the 42009 foulers and maybe you should just buy another set and try what I did. Drill halfway through one of them and slightly shave away some of the inside walls at the bottom end (not the threading) with a smaller drill bit or whatever you want to use and then put it all together. Make sure you disconnect your negative battery cable for a few minutes so that it all resets and also make sure your s-pipe o2 sensor is actually plugged into the system in case you removed it.
Old Sep 19, 2005 | 01:22 PM
BrEaK_AwaY's Avatar
as stated above, put antifouler in your spipe, and sensore in your antifouler, make sure all connections are tight, and disconnect the negative terminal on the battery (if you have an alarm system, make sure to disarm your system, if you dont do this, your alarm will sound once the battery is disconnected).
reconnect to the battery after like 5 mins or so, and see what happens...
Old Sep 19, 2005 | 01:49 PM
zoltiz's Avatar
N.G.S.O.
Originally Posted by HondaKiller
ive had my car scaned 2 times at autozone for free, and both time i got the same code p1036 bank 1 sensor 2.
never heard of p1036, but do know about p0136.
Smells a lot like damaged O2 sensor:
http://zoltiz.com/cars/tc/files/cip0136.pdf - read up
Old Sep 19, 2005 | 03:16 PM
ScionDad's Avatar
The antifouler HAS to go on the S pipe sensor and you MUST use 2 of them with one of them completely drilled out (the one drilled out is the one that the sensor threads into).
Old Sep 19, 2005 | 09:17 PM
HondaKiller's Avatar
sorry..thanks for the correction
Old Sep 19, 2005 | 09:37 PM
miamibusta69's Avatar
MIne is connected in the right place . I got my anti-fouler from clubsciontc.com. Ill go get my car checked at autozone as soon as the hurricane is over.
Old Sep 19, 2005 | 10:27 PM
Fsu1dolfan's Avatar
Question???
If i am just replacing the exhaust and the S-Pipe do i have to use an anti-fouler??
The exhaust will have a high flow cat and a resonator
sorry if this a dumb question but i am not really sure....i will eventualy (sp) be getting headers but it will be a while down the road and then i am assuming that i will replace with anti-foulers!!!!
Old Sep 19, 2005 | 10:28 PM
Kumitsu's Avatar
Hey miami, hit me up sometime i live here as well.
Old Sep 19, 2005 | 11:07 PM
The_Instigator's Avatar
Originally Posted by Fsu1dolfan
Question???
No...you only need the anti fouler when installing a header. They are needed to trick the system into theinking the pre cat on the exhaust manifold is still there.
Old Sep 20, 2005 | 10:07 PM
is it ok to just keep reseting my ecu to get my good miledge back for another 200 miles?
Just before it gets fixed? not as a solution..
Old Sep 20, 2005 | 11:10 PM
matty-tC's Avatar
yes
Old Sep 20, 2005 | 11:11 PM
ScionDad's Avatar
Yea, It won't hurt anything.
Old Sep 20, 2005 | 11:14 PM
Ok thanks is it normal that my cel doesnt come on until about 200 miles? If a sensor was broken it would come on right away right?
Old Sep 21, 2005 | 12:50 PM
ScionDad's Avatar
Yea, that is kinda weird. Have you had the code read yet. You can go to most any of the auto parts stores and get that done for free.
Old Sep 21, 2005 | 01:06 PM
BrEaK_AwaY's Avatar
that could be normal, your ecu kinda works in a cycle... not so sure in this case though
but i would get that checked out asap before more damange happens
Old Sep 21, 2005 | 11:17 PM
XD40tC's Avatar
I have a question that is a little bit off topic but still about the 02 sensors. A guy I know with a DC Header is running his header with his first o2 sensor hole plugged with some dummy one. He says he couldnt get the sensor out of his old manifold because it was stuck somehow. Now I want to know, how bad is this for his car? I was just curious as to how much this would hurt him. Thanks!
Old Sep 22, 2005 | 04:13 PM
PghtC's Avatar
how does the car run? That sensor monitors the air/fuel ratio!!! The computer probably has the car in "limp" mode where it runs pig-rich. Bad gas mileage and poor performance. You cannot just remove these things!!!
Old Sep 23, 2005 | 01:27 PM
XD40tC's Avatar
Im not sure how it runs but it still seems pretty quick. Its a 5 spd so maybe thats why it seems quick. We are having a Scion car show on the first of October and there will be a mobile dyno free for all Scion owners so I guess we'll see what hes getting. We both have the same mods.
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
supaguy
Mar 29, 2004 09:12 PM
randode
10
Dec 11, 2003 06:05 PM
Hardhitten
32
Dec 1, 2003 11:31 PM
32
Nov 5, 2003 03:49 PM
