View Poll Results: Perfered exhaust ?
Voters: 10. You may not vote on this poll
My final Deciscion ! Perfered exhaust on a N/A scion tc?
Im tide between these two exhaust systems. Ptunning sback and the ark n2 catback , help guys whats your best pic also has anyone heard them in person.
Ptuning
Ark N2
[table:e7141339c0]Perfered exhaust on a N/A scion tc[/table:e7141339c0]
Ptuning
Ark N2
they both sound great...it all depends on what look you're going for...if you like the "drift spec" look, then go with the ARK N2, if you like a little closer to the OEM look...go Ptuning. I love my N2...never regretted anything about it and anyone that has seen my car has liked it alot. I also have heard great things about the Ptuning exhaust also. And as an added note...the only difference once you're turbo'd will be that the exhaust note will be slightly quieter than before you were turbo'd
hey buddhastc does the ark n2 give any rasp or is it just deep tone , also if i get the ptuning exhaust will my car loose power due to not enough back pressure in the system??
Originally Posted by yeldak
the ptuning will be useless without having a turbo, 3" na can actually cause damage to your engine... on top of that, it will sound like the poopy.
will it benefit you? not so much
theres no damage that will be done to the car with a 3 inch exhaust, but there's no benefit either.
(assuming you are not turbo)
i just wanted to get that clarified because im about to order the exhaust. no matter what exhaust you get you wont really feel a difference in power, also i just love the look of the putuning "clean", im guessing the only think you can feel would be better throttle response correct ?
Guest
Posts: n/a
Another suggestion, you might want to post in this forum and the forced induction forum to see if anyone on the board is running our 3" s-back exhaust system on an NA car and get their feedback first hand.
MrC
If you know your goal is to be turbo'd, then who cars about whatever hp loss you may get right now from a 3" setup. You're not racing on the streets (hope not) and how often are you going to the track?
I would just get the PTuning exhaust now (since you seem to really like it and can afford it) and be happy that you won't have to modify it when you go turbo.
The only other option is to stick to stock and wait until you're turbo'd.
MrC
Guest
Posts: n/a
MrC
MrC
Guest
Posts: n/a
Just to clarify i have to remove the s pipe on the ptuning exhaust and use the factory s pipe corret ?
Only buy the Ptuning 3" Turbo-back exhaust system if you already have a turbo on the car (ie. Greddy, Turbonetics, etc).
Basically the Ptuning 3" S-back exhaust system comes with everything you need to connnect to your factory s-pipe and replace your entire factory exhaust, after the s-pipe.
MrC
oh wow thanks, love the support guys thanks alot , last question i promise lol , so the s-back comes with axel back -> midpipe-> adapter(to connect to the factory s-pipe) correct ? also my main concern is i dont want the exhaust to sound raspy i have a stock tc and a zpi lightweight pully
