P0136 code even after replacing the O2 sensor
i have about 105k on my tC and it started throwing DTC P0136 about a month ago after i changed oil (it was after 15K; yes i know i do not normally wait that long! i had also put in a can of BG44K and atleast gone two tanks before i got around changing the oil)
P0136 seems to be due to the downstream O2. i replaced it with the original one from trdsparks (denso; same part no).
after about 60 miles, the DTC came back on and the car still sounds loud.
any suggestions on what should i look for and in what order ? could it be an exhaust leak which would be a pain to find i think if that is the problem.
everything on my car is stock.
i would like to see if i can find the problem and fix it myself before taking it to my mechanic. :--)
Here is a an article that i had found on possible causes for a loud engine (it includes bad o2 sensor):
https://www.yourmechanic.com/service...mal-inspection
Not sure if our tC has a code for each of these issues or if they could be covered under P0136.
so quick update: the donut was missing on the front exhaust pipe ! after it was installed, the car sounded normal again which made me very happy :--) i will clear the code and i don't expect it to set again.
i was going through my my service records and realized that i had the front exhaust pipe replaced in 8/2014 with an aftermarket one and i am sure that the donut was still stock.
anyway, that it was not anything major.
hope this helps somebody.
