Pistons Upgrade Question
Let say at the moment I want to build my motor but also plan to go F/I in the near feature and i got low compression pistons and such all the upgrades that is best for F/I but i don't go into F/I until awhile. Is that bad? or should i go F/I right away after upgrades?
^i was actually thinking the same thing..
lower compession=lower hp right?
but then again lower compression can handle boost better right?
im still reading up on turboing cars and such so please correct me if im wrong
yes lower compression = less power.... adding a turbo is kind of like using high-comp pistons, it crams more air (which in turn makes more cylinder pressure or compression) into the cylinder, therefore more fuel is needed and a more powerful combustion occurs... I don't think lower compression would hurt gas mileage too much as long as the AFR's are where they are supposed to be....
yes lower comp. can handle more boost because there is less cylinder pressure
bootlgr
Jan 26, 2016 01:22 AM
anti_virus347
May 28, 2015 06:01 AM
anti_virus347
Apr 3, 2015 05:17 PM
