problem with draxas muffler
Old Aug 16, 2006 | 03:06 AM
cash_man06's Avatar
Default problem with draxas muffler
The problem is i just installed my draxas system and injen cai and my draxas muffler is tapping either my crossmember or something underneath. it is dark so i can't tell. has anybody else had this problem??????
Old Aug 16, 2006 | 03:59 AM
cash_man06's Avatar
can someone help on this. The tapping is annoying and i don't want it to wear a hole in this expensive ___ exhaust system..
Old Aug 16, 2006 | 04:05 PM
sp0t's Avatar
it's probably the black exhaust guard.
Old Aug 17, 2006 | 01:47 AM
garyc_01's Avatar
see if u could move the heat shield around and check all ur hinges bushings make sure everything is tight
Old Aug 17, 2006 | 01:55 AM
jwaggz82's Avatar
i had this problem. To fix it do the following:
take the exhaust off (the last part after the midpipe)
take off the heat shield and see if you see rub marks. On mine you could see tiny marks. Take a rubber hammer and bang it like the girl next door. Then put it back on and see what happens. Since you are putting a larger pipe then stock AND the 1/8th movement back and forth of a vibrating pipe (so thats 1/4inch movement total) ... its causing the pipe to very very so mildely touch the heat shield. This is how I fixed my issue - hope it helps.
Old Aug 17, 2006 | 02:35 AM
garyc_01's Avatar
yea.. take this advice from jwaggz. i told him wat to do sorta haha...
Old Aug 17, 2006 | 03:28 AM
cash_man06's Avatar
thanks for the tips... I found what the problem was... My exhaust was hitting the crossmember. I wrapped some header wrap around the crossmember and problem solved...
Nottingram
Jun 25, 2015 07:50 PM
hagpup
Mar 30, 2015 12:38 PM
Jumphiggggg
Feb 13, 2015 04:05 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
