!!!Problems coming from under the hood!!!
well not to sure if what it is but my tC is make lets see how to explain chirping noises??? kinda like when the belts get old and they start making noise and i already replaced the belts and the noise is still coming out but i do know that when i pop the clutch in it goes away can anyone help??
CHeck the two 10mm bolts on the top studs of the ac condensor - car rattles the most (shakes) at idle - these somehow came loose on mine after one of the motor pulls and made an annoying ___ chirp at idle. Also really anything thats metal on metal and not tight could make this noise
is your car standard? I had the same problem with my 2007 tc i had the trd supposedly heavy duty clutch and fly wheel which is complete junklike all trd parts lol my car made the same sound before my clutch burned out 6000 miles later . I only got 20,000 miles on that thing waste of a 1000 dollars + interest i have an exedy now and its lasted twice as long so far.Listen close when you switch gears if your standard I heard the chirping and also a wierd whining sound during gear switching and just the chirping when i drove or stood still.
Also some types of new tires can give a chirping affect that can appear to be from the car
I think your on the right track cause the guy from the dealer said something about clutch but didn't really say what exactly
Originally Posted by cburglb34
throw out bearing
Worry about now is they covered under an extended warranty? If anyone knows
Originally Posted by cmcpride
only if its a factory clutch, but whats your local dealer west covina toyota?
dunno if the throw out bearing is warranteed after like 12k miles but u can try and if not u might aswell just buy a whole new clutch from exeedy cuz itll cost the same amount for toyota to put in a factory clutch
