pulley question
i been looking for a little while now and i cant find a clear answer.
ok there is 3 pulley right, i know the crank is the main one.
you gain the most hp from that one, or gain same from all 3?
what estimated gains from each? is it really worth getting all pulleys?
but im just saying what should i oreder for the best hp gains, and is it really worth getting all of them? or just the crank (underdrive i believe???) i wanna put all my mods on next weekend so i can feel a good gain
In a very very small nuttshell...
1. All NST pulleys are roughly 70% lighter than the OEM pulleys they replace. The more NST pulleys you use, the more weight reduction. The more weight reduction, the better the throttle response. Having said this... obviously the crank pulley is the heaviest of all the pulleys and thus, changing to the NST crank pulley will provide the most noticeable gains when compared to the rest of the pulleys.
2. The electrical system runs just as well, or better than stock, when a full (3pc) NST kit is used. NOT slower, NOT weaker, etc. Any arguments other than this are simply not valid. PERIOD.
3. Other accessories work very well when NST pulleys are used. Customers using full NST kits have reported no issues of any kind when using NST pulleys.
Not all pulleys are created equal. Not all pulleys are NST pulleys. Theories, myths, and horror stories associated with cheap, low quality, knock-off pulleys DO NOT apply to NST products. Period!!!
are you inplying the to the over or under driven pulley sytems because if you under drive your cars elecrical system it is going to perform weaker how could it perform better, if you Overdrive it i would believe it would perform better but not underdriven
you mightaswell do all 3 while yur at it. Ive heard good things from people with the whole set. I myself have a brothers lightweight pulley. Dint wanna change the Oem size. Still feel a good pull.
thanks i was jsut looking at the NST belt guide page and saw that the crank would require something different. Im looking to get the underdrive pulley, etc, but need to wait till spring and find someone to install them. Thanks.
yes, underdrive crank pulley needs a new belt, the other two are the same size, so you can run that stock belts...
now if you get the lightweight pulley you dont need it, just with the underdrive
