Question: 09 Header On 06? Going Stock
Old Jun 20, 2009 | 12:54 AM
Dilirious's Avatar
Default Question: 09 Header On 06? Going Stock
My question is will an 09 header and spipe fit on a 06.
If it will which gaskets do I need to use 09 gaskets or 06 gaskets?
Thanks
Jeremy
Old Jun 20, 2009 | 05:54 AM
Dilirious's Avatar
bump anyone?
Old Jun 20, 2009 | 06:11 AM
elcapetan's Avatar
it will however the mounts on the bottom will not line up. NP no one really cares. To answer your question yes it will no need for a different gasket.
Old Jun 20, 2009 | 06:27 AM
draxcaliber's Avatar
gaskets are the same regardless.
Old Jun 20, 2009 | 06:57 AM
elcapetan's Avatar
yep just throw it on. no modifications required.
Old Jun 20, 2009 | 03:29 PM
Dilirious's Avatar
thanks for the info,
Reason i was asking about the gaskets too is because the part numbers from a 06 to and 09 are different.
Old Jun 20, 2009 | 04:30 PM
BZinn1's Avatar
from what I have seen from both they look interchangable,not sure hwy the part number is differant........figures they would do it since the header from 06-09 are differant numbers so maybe that is why,the mounts on the lower block seem about the same too......should be fine.
SloTC1
Apr 2, 2015 07:11 PM
AstraXtreme
Feb 25, 2015 04:24 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
cacafria97
Jan 12, 2015 01:34 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
