Removed Balance Shafts. w/dyno
Originally Posted by bluaeon
Originally Posted by adg016
With our shafts removed and our oil cooler setup, our capacity is now 6 qts.
http://www.nissanperformancemag.com/january05/specv/
http://www.jimwolftechnology.com/cus...asp?PartID=432
installation: for Spec V
http://www.nissanperformancemag.com/november04/specv/
did you guys use any of these... i mean something like this?
Originally Posted by TCpete
watching.... hey Dan.. would this harm the motor at all??
navylife59 wrote:
The balance shafts are driven directly off the crank so why do you need a "Kit"? The balance shafts are there more than just for creature comfort. It is an inline engine, as such, there are no counter-oppossing forces to cancel out the inherent harmonic distortions. HD can be real engine killers if left unchecked. If you remove BS then you wil need a full balance on the rotating assembly, forged assemblies, and a fluid dampner to make the motor last.
adg016's POST
Wrong. These are second order harmonics that vibrate the block and consequently transmit vibrations into the cabin. This is something most consumers will not tolerate. They bear no deleterious effect on the internals at all. If anything the shafts put more strain on everything inside, since other parts are stressed having to spin them. In addition they churn and aerate the oil.
Yeah, it vibrates. I don't know if it would bother you guys or not. I have no idea what your tolerance level is. You have to remember I also have solid motor mounts and my car is a race car. You may elect not to do this for a daily driver.
lol i really dont care for comfort and have a high tolerance..... i'd like to try this on my car... hmmm
question...the oil pump has a chain that is driven by those balancer shafts along with the timing chain itself going down to the gears so how exactly did you removed the balance shaft assembly and not affect the oil pump and the timing chain?
Originally Posted by toyota_scion_tc
Just like adg016 said it will harm the internals if you have not balanced the rotating assy and installed a fluid damper.
There u go, for the record. DONE.
Extra info for all of you:
http://www.hondaprelude.to/forums/sh...ad.php?t=22359
http://en.wikipedia.org/wiki/Balance_shaft
