S-Pipe install and exhaust leaks
For those who did their s-pipe installs themselves - how did you address the back flange gasket issue - the flange that's connected to the mid-pipe.
I've got a used ZPI s-pipe, and the front (header) side bolted up beautifully, relocated O2 bung also was not an issue, but the rear flange is giving me issues. First I had to go and buy 10x1.25 nuts because the s-pipe did not have them welded in like the OEM one does, then I tried to rig an exhaust gasket there, but it still leaked, so I put everything back to stock.
From what I heard, that shoul apply to most other s-pipes, too, not just ZPI.
Any insight is appreciated.
Another gasket was my plan for tonight. You think if I take a small ratchet and hold the bolt from the back, then I can wrench the nuts from the front of the flange? The car will be on rhino ramps, so there is not a whole lot of space to work under there...
yes you have to hold a wrench on the nut and use another on the bolt. if you arent doing that then it isn't getting tight enough to keep the exhaust from leaking. do that and get a new gasket you'll be set.
not all of the s-pipes are doing this. i just installed invidia's on my car last friday and it was a beautiful fit. no problems at all. it came with new bolts and gasket for that flange you are having trouble with. no leaks at all.
Originally Posted by zoltiz
I got a new 2.5" gasket and an extra set of wrenches so that I won't have to use an adjustable one. We'll see how it works out when I get home.
Any tips for fast exhaust cool down? :D
Gloves! That's what I forgot last night. I remember looking at them and then I climbed under the car and got distracted. That should speed up the process. That, and not having to screw with an adjustable wrench and an incorrect size gasket...
i know this is an old thread now but to the question on how to cool down the exhaust quick or any part of the engine bay for the matter, i pull out a small 10" fan that i can sit on the floor.
if i'm going to be working on the top or under the car i just prop the fan up on top of the motor and it helps cool down time speed up. it still isn't instantly but it helps alot more than you might think.
Re: S-Pipe install and exhaust leaks
Maybe there are different versions of OEM exhaust, but in my case the stock gasket was smaller than 2.5", and required a small section of piping sticking out of the s-pipe flange in order to be centered.
I'm stupid. Did not even think to look at the mid-pipe. In part due to it being very uncomfortable to work under there - I don't think I could have turned around to look at the other piece of piping.
In any case - thanks, I'll be smarter next time :D
my06tc
06-25-2015 12:18 AM
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
TheRedBox
31
12-02-2003 04:53 PM
